OT - Crabgrass Treatment
Brian in Sandusky, OH
>I'm going to be treating my lawn for crabgrass soon.
My understanding is that the most critical item I need to think about here is timing. I've read that around the second mowing of the season is the time to treat. Any thoughts here?
Next thing is selection or brand of treatment. I'm going to use something granulated with a broadcast spreader.
Any brand recommendations? I have about an acre (roughtly 4500 sq feet) to treat. The bags that I found range from $12-18 each, and each bag will treat $5,000 sq feet, so at a cost of $108-$162.
Should I go with the higher priced brand? (I think that it's Scott's brand)
Suggestions?
Thanks in advance.
Re: OT - Crabgrass Treatment
Ted Wong
>If your area climate is anything like our climate near Cincy I'd say it's too late. I've already seen the crabgrass coming up around here.
wilbur
>The best time to deal with crabgrass is before it starts growing with a preemergent weed control. I use the Scotts fertilizer/crabgrass preventer combo, which is the one with the blue label. The rule of thumb is to spread it before the forsythias bloom, which they did here in New Jersey last week. I put mine down in early March. Judging by the temperature bands, you may be too late for this, but it couldn't hurt to spread it around, unless you are thinking of seeding your lawn in the next few months. The same stuff that prevents the crabgrass from growing will also interfere with grass seed germination.
Once they grow, you could try the various crabgrass killing products, but I haven't found that they work very well. I have a small yard, so the first year I wound up pulling the crabgrass clumps, which worked much better than the crabgrass killers.
Finally, try to seed the bare spots in your lawn in the fall. Crabgrass can't grow if the regular grass gets there first.
Bart Goldberg
Bart Goldberg
>If you will permit me to make a slight correction to your timing suggestion. In NJ, you must apply a crabgrass pre-emergent before the Forsythia blooms fall. Its okay to apply before they bloom, but its too late if the blooms have fallen.
Also, the type of pre-emergent is different for different situations. If your planting new grass seed, you need a selective pre-emergent. The one that come to mind is called "Tupersan"(sp?). This will not interfere with new grass seed. The kind in the Scott's product mentioned in another post is a non-selective kind and should not be used when putting down new grass seed.
In any case, the brand is not so important, but the chemical composition is. So check the labels and see what your getting and in what concentrations.
Hope this helps.
Bart
Dale Lenz
Re: BTW....
Dale Lenz
>an acre is 43,560 sq. ft. maybe you had a typo on your sq. footage?
Re: BTW....
>yeah, thanks...
I have a little over an acre, so I just put it at roughly 4500.
Funny, because after pricing this all out, I called a landscaping company, and for about the same price, they can do it for me.
I'm leaning that way.
Re: BTW....
Glenn Madsen on the road from SF Bay area
>They got the 'over-an-acre' estimate, right?
That's the way I'd go. Pros can get stuff you and I wouldn't find or need very often...
Need to add an extra "0"
John E. in SC
>"A little over an acre" is 45,000, not 4500 sq ft. What did you tell the landscaper? That might make a huge difference on your price quote (X 10!)
Sorry...typo...45,000
Hire the service
Joe Pack
>You are right, Brian. A lawn service can do your lawn for not much more than you can buy the materials for, and they can get better stuff than you can.
I had a service do my lawn for many years, then, thinking I could save money, went the DIY route. I used the same routine as the service. At the end of the season I had saved about $30 and my lawn did not look nearly as good as with the service. My time was pretty valuable then, so I spent the $30 the next year and went fishing instead of playing gardener.
