Split Log OK?
Split Log OK?
Split Log OK?
Joey, Ct.
>A large tree fell quite a few years ago (25), but never made it to the ground. It looked rotten, but isn't. Very tight grained, air dried oak, ( I think ), but a very tight split along it's length. I now have 6' logs, ( a little short but that's all I could haul out of the woods myself ). Can I run these through my band saw, ( with riser ), addressing the split? If yes, which blade and which issue do I vaguely remember a band saw carriage. Thanks Joey
Re: Split Log OK?
Depends on the weight of the log...
Mike in Paradise
>I have made a carriage to hold a log using a pipe clamp and have done shorter stuff about 8 inches like that.
If it too long, or too thick a log than there will be a lot of weight and you will need to have supports on both sides of the bandsaw.
I use a 3/4 inch 3 tpi blade.
Free Image Hosting at www.ImageShack.us
Image Hosted by ImageShack.us
Re: Split Log OK?
Only use the carriage for the first cut
Mike in Paradise
>after the first cut I just run the flat edge against the fence to slice of the individual boards.
Re: Split Log OK?
Re: The first cut is the deepest
Joey, Ct.
>Thanks Mike; I have just the pipe clamp. Can't wait to set up the BS with a similar blade. I was thinking of an Alaskan lumber mill, but maybe I don't need one. Joey
Re: Split Log OK?
I have an Alaskan mill as well..
Mike in Paradise
>It is much faster and easier with the Alaskan but you lose more wood with the wider cut and you need a decent size chain saw. I have a Stihl MS660 that resides in the mill.
