Dado Blades can be dangerous
Matt Berry
>Since I'm such a big stickler for safety, and I think accident reports are an important reminder / learning lesson for others. I wanted to share my tablesaw mishap with everybody. The tablesaw in question is an underpowered craftsman direct drive contractors saw which can normal be stalled in most situations.
Yesterday I had a couple of rails that were 2 1/2" x 13" x 1 1/8" thick that I wanted to rip a dado 5/8" wide x 3/8" deep down the center of the edge, to accept a flat panel.
On the first rail I started the cut, and the little voice in my head said wonder if this piece is long enough to make it over the dado blade and still be supported by the throat plate (my dado throat plate has a space to the front and rear of the dado blade). So I stop the saw and do a mock run through, everything looks ok. Still not 100% confident with the cut I start the cut again, watching it very carefully ensuring the piece didn't tip or pull away from the fence.
as the front of the part made it just past the half way point on the dado blade, POW, the part kickbacked, peeling back a layer of skin on my thumb and "jamming my thumb" pretty good, there was a little bit of blood but nothing major.
So what happened? Well as the part went forward the force of the dado blade caused the nose of the rail to tip forward (no side to side movement) the gap in the throat plate behind the blade added to this threat, and allowed the blade to dig into the wood and launch it.
How could this have been prevented, well there are a few things that could have been done differently.
1. Use a longer piece of stock to cut the dado in then cut to length (not quite an option here since this was 4/4 stock finished planed to 1 1/8" thick a feat in itself)
2. Make or use a zero clearance insert for the dado blade, could have also constructed a sled or jig to give the part more support.
3. Use the tablesaw for what it was truly made for to hold lathe accessories, and or hand tools. Let this be a lesson to all other turners out there don't deviate from a tools true use.
4. Probably should have been using a push shoe from the beginning of the cut.
Ok, so what went right, well, no amputations or contact with the blade. Why, well here are some of the reasons why.
1. never have fingers in a direct path of cutter, (especially if applying pressure twords the blade) whether hand is in front of or behind the blade.
2. Stance, well balanced, so if piece isn't there I won't lunge forward into the blade.
3. Cutter safety zone, I have a safety zone around the blade where I don't allow my hands or fingers go into.
My thumb is still a little sore from being jammed but I expect it to be better by tomorrow. I just hope this helps someone else be safe.
