A55 Smoothing Plane
routing a depression
brad bransky, lawrence, ks.
>How does one create an oval or round depression with smooth slanting sides in a wood surface with a router the purpose of which is to slide out a bead or fish hook such as would be found on a portable fly tying bench. Thanks Brad
Re: routing a depression
John McGaw
>And how big (diameter and depth) might this depression be? The answer will vary greatly for a 1-inch or a 2-foot size.
good point!
>Thanks John. About 2" x 1 1/2" oval and about a 2" round.
Re: good point!
John McGaw
>I'm afraid I'm being especially thick this AM. Assuming a 2" round depression, how deep would it be? If it is very shallow, perhaps 1/4", I would not even use a router. A fairly coarse sanding disk on a 2 - 3" diameter foam backed sanding disk on my right-angle drill should be able to make such a depression in a few minutes. As long as the drill is kept moving evenly the depression should be relatively even.
For large depressions it is possible to rig a router in a jig which makes it swing like a pendulum. Depending on the length of the pendulum shallow to deep depressions can be routed in various diameters suitable for serving pieces made from large wooden slabs.
Thanks John!
>I like the sanding disc idea. I also found a router bit called a "core box bit" which might work if I can make a decent template. Thanks, Brad
Re: good point!
Curly Smith
>Make a template the desired size then use template guides to achieve the desired depths (small or no guide and shallow depth on the outside, large guide and deep depth in the center). Use the full range of your guides and you should get a decent oval depression.
Curly,
>Excellent! Shall do as soon as I get to Woodcraft today in Lenexa to get the guides. Aaaah, another tool!
Brad
>Brad, I have a core box bit that is 1 1/2". I used it to make a bunch of round bottom holes for a jewelry box tray. Seemed like a good idea, but it came out looking like an egg crate, a really pretty egg crate, but still and egg crate. The bit was not cheap, but I find a lot of uses for it. Incidentally, In order to get those holes nice and even, the guides and patterns had to be VERY sturdy. A bit that big is powerful and really wants to wander around.
I don't know how "perfect you want you ovals, but that bit does not make them very well. If you make a template that is a rectangle and use a collar and run the bit in it you can get a hole that is 1 1/2" by 2" but it is a cartouche, not an oval. I think you could get attractive "oval-ish" holes with rounded bottom with one if you used an oval template, but there would still be a flat place in the bottom.
David Marks on his Woodworks show sculpted a bowl in a table with a set of curved router rails that tracked the router through a path sort of like a pendulum and then he rotated it degree by degree until he had gone through a full circle. If you had a 1 1/2 or 2" core box bit you might get a small depression in a single pass with curved rails.
