Another veneer question!!
MountainMan
>I have wanted to post this for quite awhile - I need help on the deteriorating(sp) veneer on a table top... I bought and brought it from Belgium 20 years ago - neat corner unit with padded benches and two chairs.. anyway the top is starting to shed some of the veneer... I don't quite know how to handle the situation - I'd hate to have to re-veneer the whole table top... so far the affected portions are about 2 or three in. by 1/2 inch or so.. Any ideas??
Regards
The MountainMan
Re: Another veneer question!!
Lee Gordon
Lee Gordon
>Any chance there's similar veneer on the underside of the top? If so, maybe you can try stealing a little bit to make a patch.
Veneer repairs
>You didn't mention the nature of the deterioration. Is the veneer lifting from the substrate? Is any of it missing? You can glue down loose veneer quite easily. If you need to replace missing veneer, you can carefully make a patch and cut it in, then finish it to match the surrounding veneer.
Re: Veneer repairs
MountainMan
>Hi Ellis
Yes, a small amount of veneer has seperated from the sub-strate - who knows when?? Probably started with too hot a dish being placed on the table with no protection... I'll have o look under the top - can't remember whether it is with veneer - probably does have it...
Regards
The MountainMan
