Veneer question
Ted Wong
>I have a student that wants to veneer a hollow core door slab. It's half of a bi-fold door and measures 12" wide x 80" long. The slab is typical hollow core construction. 1/8" door skins sandwiching corrugated web and solid 1" edge all the way around.
I'm not sure if she should veneer both sides of the slab or if she can get by with doing only one side with no ill effects. She plans on using formaldehyde resin glue and will be clamping in a vacuum press.
