Shiplap joint for plank flooring *LINK*
Fred
>I have some Pine/Hemlock wide plank boards that I would like to use for flooring. I would like to cut a shiplap joint on the ends similar to the image linked here. What would be the best way to cut such a joint? A router, or perhaps a dado blade on a table saw?
Thanks.
Plank Flooring Shiplap Joint
Re: Shiplap joint for plank flooring *LINK*
>A router would work but I think if it were me I'd use the table saw. I'd use a crosscut sled and a dado blade. If you are doing flooring then you'll have many to do. The crosscut sled will provide support and safety and be a quick way to knock off a lot of boards expeditiously.
Tom
David Hay @ Denver
>I agree that using a dado blade in the tablesaw is probably the best bet in this situation. With a router, you're going to want to make multiple passes to keep from breaking or otherwise wearing out the bit or router. With the tablesaw you could make the entire rabbet in one pass.
David
>Table saw and dado, by all means. Just be sure to joint and rip the boards so they're exactly parallel first.
You should put a slight champfer on the two top edges as well; improves durability of the wearing edge.
If you're going to lap the end joints (rather than butt them) it'll be easier to use a router in two passes with a clamped fence.
Paul Woolson
>I'm confused how a crosscut sled would come into play here. Aren't these joints cut the length of the boards? If so, wouldn't a fence be the setup uses?
Re: Confusion
Kneale Brownson in Northern MI
>OP says he wants to put the shiplap joints on the ends of the boards.
See Kneale's response above.
Don Henthorn
Fred
>Thanks. I don't have a jointer. How critical do you think that is to the job? The planks were rough cut (and edged) with a band saw and the edges look pretty straight. They will be planed to 3/4", then I'll rip them into 12/10/8/6 inch widths as necessary before cutting the lap joint.
My goal is a rustic appearance to match existing floors in 150+ yr. old house, so some imperfections are acceptable.
OTOH, I see low end bench jointers in the $200-300 range which would probably be sufficient.
Re: chamfer clarification
Fred
Is this the edge you are referring to?
xxxxxxxxxxxxxx\
xxxxxxxxxxxxxxx\
xxxxxxxx
xxxxxxxx
>See the "pic". Since pine is a soft wood, a crisp square edge on the top will tend to break and splinter, even with finish applied whereas knocking off the corner with improve wear and prevent this kind of damage. Doesn't need much, a 1/16th is sufficient. You can go with either a true champfer with a flat surface (left) for a more formal look or a roundover (right) for a softer look depending on the application. You can also just sand off the edges for a "rustic" distressed look, but I prefer the control that a router bit gives.
MM
>Fred,
If you're going to cut your laps with a table saw, you need the board edges precisely parallel and straight, otherwise your joints will be uneven. Boards that are not even and straight in width will make it nearly impossible to lay a straight floor.
You can substitute for a jointer by attaching your work pieces to another board you know is straight and even. The guide or guage board needs to be almost the same length as your workpiece so that your rip cut is fully supported by the fence. You make your first rip cut with the straight board riding the saw fence. Then separate the pieces and use the fresh rip cut to ride on the fence for the second rip. Your board will then have parallel edges. There are two ways I have done this as illustrated. The work piece either lies edge-to-edge with the guide board as in "A" and is attached at at least two points of contact between the two, or it lays on top of the guide and is screwed to that board leaving a minimal amount of unsupported workpiece near the blade as in "B". If you use method "B", you can make the guide board into a formal jig by mounting 3 or 4 hold-down clamps along its length and thus avoid putting screw holes in your workpiece.
When you're ripping, make sure that you cut enough lineal footage of any given width to make a complete course plus a foot or two on your floor. Remember also to leave enough gap in your installed lineal joints for the floor to expand and contract seasonally. You'd hate to go to all this work only to have your pretty floor buckle up long about the 1st of August.
Hope this helps
Fred
>Your pics make it perfectly clear. Thanks.
A suggestion
>You're welcome. Hope it gets you where you want to be.
Don't know how thick your stock is (and I've not use pine myself), but I would consider leaving the overlapping part of the joint heavier rather than trying for a 50/50 cut as shown in your link. I think it would be a stronger option.
Post a photo when you're done.
