Attatching the top of an entertainment center
connie
>Long time lurker, infrequent poster.
I need to attach the top (70x22 qswo) of an entertainment center to the plywood carcass (essentially a plywood box with a solid top faced w/qswo) that forms the body of the piece. The top will extend appx 1.5 inches on three sides, and I have not planned for a moulding to cover the intersection of top and carcass. Figure 8's would be visible at the edges and would not work. What to use and where to put them is the question. Obviously I could drive screws up from below, but this just doesn't seem right to me on this piece, although I could easily plug the holes. If I used dowels or biscuits or just glue I worry about wood movement. Please help.
Re: Attatching the top of an entertainment center
Larry in SE MN
>If you can cut a slot inside the case and near the top of the sides and front, you can make use of these top fasteners from Rockler. The slot can be made with a biscuit cutter or a slot cutter bit in a router. You can also use several shallow drilled holes of 1/2 to 1" diameter in place of the slot.
http://www.rockler.com/product.cfm?Offerings_ID=784&TabSelect=Details
You can also make your own fasteners from scrap hardwood blocks.
Pat Evans
>Would blind sliding dovetails cut in from the back work?
Bob Lang
>What's wrong with screws? If I'm understanding this right, you have a top on the plywood box, and the overhanging top is solid wood. You need to accomodate the fact that the solid wood will move at a different rate than the plywood. Oversized holes in the plywood and screws from below will accomplish this nicely and with a minimal amount of fuss.
Visually, the discrete placement of a few screws on the underside of the inside of the carcase shouldn't bother anybody. I'm betting you'd have to really work to see them once the piece is finished, in the room and full of gear.
my $.02 and fwiw Gus Stickley would have used screws & figure 8s without a moments hesitation.
Bob Lang
Jim Dillon
>Connie,
You didn't say how tall the entertainment center is. If the entertainment center is tall enough (so you wouldn't normally see the top), a variation on what Bob suggested would be to enter the screws from the top of the QSWO. Carefully mark where the plywood sides of the carcass intersect the solid wood top. Then bore several (3?) holes on each end. The middle hole need not be elongated, but the other two must be to allow for expansion of roughly 3/16 to 1/4 inch total. Then place a screw roughly into the center of the elongated hole. You could countersink the screwhead a bit if you wanted. A washer-head screw intended for attaching drawer faces might work well.
However, if the center is 35 inches high or so, then any of the suggestions would work well. If your center does indeed have a plywood "top", then just use a regular square head screw placed into two elongated slots (and one non-elongated hole in the center) and then cover up the screw/slot with a plastic screw cover available in several colors from McFeelys. Whatever method you pick, be sure to allow for expansion of the solid top; and it probably isn't a good idea to pick up your center by the top alone (regardless of the method used) - especially if it is loaded down with stuff. Good luck.
If I've misinterpreted what you are doing, please don't hesitate to clarify things.
Jim
Al Stokka - Cambrige, Iowa
>Connie,
You could rotate the figure 8 fasteners 180� from the position you described. Doing so would make them visible only inside the case.
Al
Use a frame!
Lee Schierer, McKean, PA
>What I normally do is make a frame our of 1 X 2 that fits inside the carcase and sets about 1/8" below the top edges of the sides and face frame. This frame also aids in getting the cacase square and stiffens it up considerably. I secure the frame in position with pocket hole screws, with the pockets on the top side so the aren't seen from under neath. Once the frame is in place, I run wood screws up through the bottom of the frame into the bottom of the top.
Lee
connie
>After seriously considering a blind sliding dovetail, and further researching wood movement, screws in slightly elongated holes in the plywood won. They are hardly visible, and look better than I feared.
Thank you all for the help. I needed to be re-assured.
