Digital Photo & PhotoShop Question
Mark Kauder, Phenix City, AL
>I have a decent enough 5mp Canon digital camera. It drives me crazy though with some of the things it does. 1) It goes through batteries like you know what through a goose. But that is not the problem. Here is the curret problem (probably been there for the last year, but have not noticed, or I changed some setting accidentally.
The problems is, when I take pictures of my woodturning turning the camera on it's side (Portrait?), when I pull them up in Windows, Fireworks, Photoshop, whatever... The appear shorter/fatter than they should be. Then when I rotate them 90 degrees to be in the right orientation, then end up tall and skinny (see the photo below), by changing the image size and only changing the appropriate dimension, I can make it right. But what gives??
Mark
Re: Digital Photo & PhotoShop Question
nailshooter
>If the image doesn't do that when you take your picture with the camera in the normal position, your software may (probably?) be responding to the EXIF camera settings/info in your binary files.
Try turning off the "read EXIF information" aspect (wherever that might be!) in your software and you will probably have it.
If you have changed or upped the pic size, this makes the "viewer" in your browser squeeze harder to get the image in the screen, and it can make some incorrect guesses along the way. You should also try turning off the "fit images to screen" in your software to see if that does it.
Robert
Rick Christopherson
>It is probably just the aspect ratio of your monitor that is making them look odd. PhotoShop does not alter the pixel ratio unless you specifically make it do so. Look at the resolution settings for your monitor.
>Mark in photo shop when under Image size there is a box the says Constrain Proportions. If you uncheck that it might solve your problems. Also on the Crop tool if you have it sized for 5x7 you may have to change it to 7x5. As you know I'm not computer literate so those are just wild guess's. I have the same camera as you and I don't think it's the camera but would have to look through the menu to be sure.
First eliminate the monitor
>There can be various things causing this, but before we go too deep, what type monitor are you using and what are the settings. I have the fortune of having many computers hooked up to several different monitors and two identical pictures can look fat/skinny like you describe based on the monitor and it's settings.
If you have a standard aspect-ratio monitor (not widescreen) make sure it's set to something "standrd" like 1024x768 or 1280x1024.
Next, let's eliminate PhotoShop. Can you take a few pictures and then copy them to the PC using WindowsExplorer. Don't rely on any special Canon, or whatever software, just a simply copy/paste at the file/folder level. Then open the pictures using IE. How do they look?
Report back and we'll look at the next things.
Happy Woodworking!
Batteries
Jerry Nicholson
>What kind of batteries are you using? My Canon G6 uses a Canon proprietary L-ion battery that provides excellent service but some cameras use AA cells. I have had excellent luck with Radio Shack (of all places!) AA NiMh cells in digital cameras. You can get a set of 4 with a charger for about $20.
Jerry
Philip Duffy
>Mark, I have disgarded all pic s/w now that I have discover Picassa 2, a free Google product. Amazing. Phil
Batteroes *LINK*
ScottS
>Regarding your battery problems:
Buy rechargable batteries (if possible)! I use Maha PowereEx batteries and a Maha charger from Thomas Distributing. My charger has slots for four AAA or AA batteries. Each of the slots is a separate "bank", which means that you can charge a single battery at a time. Some of the less expensive chargers require that you charge batteries in pairs, which is inconvenient for me since I have several devices that take an odd number of batteries. The charger I use is, I believe, the MH-C401FS. I bought 2700 mAh NiMH AA batteries, which seem to last quite a while between charges...
Thomas Distributing
Good point about camera software
Rick Christopherson
>I never use a camera's bundled software for getting pictures out of a camera, so I hadn't considered the possibility that that software could be reinterpreting the image as it downloads it from the camera.
Most cameras these days can be interfaced as though they were external hard drives, and that is definately the way to go.
Re: Good point about camera software
nailshooter
>I don't use the camera software as so much of it is just geared towards getting the images off the camera. So many make that so hard...
I have a Canon 10 megapixel, and the images can be quite large. But using Xnview it can preview 750 mb of pics into thumbnails in seconds. The included software takes much longer and has a really awkward interface.
I got Xnview many years ago, and the newer version has a life of its own. Their support forum was where I found out about the EXIF info. I wasn't sure what it was, and had no idea it was so sophisticated. I also had no idea that almost all modern digital cameras embed that info in the image somewhere.
Now that I have that feature turned off in the software, and it just downloads the images as jpegs, so everything is back to normal.
Hope results are posted when the culprit/setting is found out.
Robert
Re: Batteries
>Jerry, (an all)
Sorry, I had a brain fhart when I posted. I actually have a Sony Steadyshot DSC-H1. I used to have a Canon A-1 for years and years and it is stuck in my head. Anyway, I searched all over the internet and apparently, this is a defect in this camera that is somewhat better in th H2. I took all the advice from the forums, and the batteries I am using now, last for maybe 40 pictures instead of 15-20
Thanks Jerry
Mark
Re: Batteroes
>Thanks for the link.
The ones I use now are NiMH 2500mAh and are working OK.
It all came to a head in our Christmas European trip, when we were buying pack after pack of AA batteries each day AT EURO PRICES!!
Mark
Re: Digital Photo & PhotoShop - I am a Dope!!
>Mark Goodall (et al)
You were right, it was the aspect ratio of my Laptop display settings.
Some how that did not enter my head (that is why I mess with servers, and not PCs so much).
Anyway, Now that I have corrected that and I look at my original post - the upper left photo - the original from the camera, is actually right.
Thank you all,
Leaving with tail between legs.
Mark
Re: Batteries
Bob Fawcett
>Time to go back to a Canon. My old G2 will over 300 pictures on one charge.
Re: Batteroes
Charles Self
>Mark, Try the new hybrid batteries. They hold a charge longer than standard NiMH, and, at least in my cameras, give a lot more shots. I was getting 400 to 600 with standard 2500 MAH NiMH cells, and I get about 700-750 with these. In the states, I've only found RayOVac which sell for about $9.95 for four at WalMart. Use your standard AA charger for them. Eneloop is another brand name, I think from Sanyo.
