Bandsaw problem
Bandsaw problem
Bandsaw problem
Mitch from TN
>This afternoon out of nowhere my bandsaw stopped working. It's a craftsman 14" a few years old. I turn on the switch and hear a loud hum and the wheels don't turn. I haven't had any problems with it lately. Today, it just stopped. I checked the wheels and I can turn them manually. Any thoughts on what to do?
Thanks!
Mitch
Re: Bandsaw problem
Re: Bandsaw problem
>Sounds like either your starter capacitor on your motor or the starter windings have gone bad. The capacitor is easy to replace. Just take off the existing one (its the thing in that little "OJ" can on the top of the motor) and take it to a motor repair shop.
If its the starter windings you may have to take the whole motor to the shop and have it rebuilt. If Its an "open" motor, the first thing I would do is try blowing it out through the holes with compressed air. It may have debris in the contacts. Unplug it and blow it and spin it at the same time.
Wonder if you could give t a spin by hand and get it going? Sounds like something I would try. Probably not smart.
Re: Bandsaw problem
Re: Bandsaw problem
gil Jones
>Check the start capacitor with a meter, and/or check the centrifugal switch (it removes the start capacitor from the circuit after spin-up).
You could remove the drive belt, and (with the power switch turned ON), CAREFULLY hand-spin the motor in the normal direction of rotation. If it spins up and runs OK, it will 'probably' be the capacitor and/or the centrifugal switch causing the problem. [I am assuming that your motor has a start capacitor and a centrifugal switch]
Gil
Re: Bandsaw problem
You Could Even Remove The Blade First
Re: Bandsaw problem
Re: Bandsaw problem
Dan Donaldson
>If the motor is not the totally enclosed type, then the most likely suspect would be dirt in the contacts of the centrifugal switch. Try taking an air hose and blowing out the motor. If you can manually spin the motor and it starts, then it is either this or the capacitor. (obviously, be careful about spinning the motor. The way I try this is to wrap a cord around the pully, give it a yank to spin the motor, then apply power after my hands and the cord are well away from it.)
Re: Bandsaw problem
WARNING
DB
>Do not touch the terminals on the capacitor. It may be terminal, but most likely just a nasty shock if you do.
Re: Bandsaw problem
Re: Bandsaw problem
Phil Thien
>I agree w/ Dan. Blast that puppy w/ your air hose. Works every time for me.
