Should know
Should know
Should know
Don Henthorn
>and probably did at some time but have forgotten. Can you use rubbing alcohol to mix shellac?
Re: Should know
Re: Should know
>rubbing alcohol is typically 70% isopropyl alcohol. The rest is water. You could use it. You'd also regret it. Way too much water.
Re: Should know
Yeah , JL
>Don, It would rub you the wrong way.
George
Re: Should know
Thanks, Now I remember why.
Don Henthorn
>Tough to get old and forgetful.(G)
Re: Should know
Re: Thanks, Now I remember why.
Ernie Miller
>use grain alcohol or Bacardi 151 in a pinch. ust mix the wife's margarita a littl weak she won't miss it.
Re: Should know
Re: Should know
Dave Bair, Eaton Rapids, MI
>Isopropyl can be found in a variety of concentrations. I've done well with the 90% and 95% varieties. It'll slow down the drying time; a distinct advantage on a hot, dry day or if you're just a slowpoke like me.
