THE WOODRAT IS BACK!
Shopmade Shelf Drilling Jigs
Dan Clermont
>My wife wants to add some shelves to a cabinet I made. The cabinet has been installed. I have procrastinated on this long enough and need to make a shelf drilling jig.
Anybody got plans/drawings/explanations/diagrams of jigs they speak highly of?
Thanks
Dan
Re: Shopmade Shelf Drilling Jigs
Bob Lang
>My cheap and easy solution is to cut a scrap of plywood to fit inside the carcase. I wouldn't make it a tight fit-I'd make it to register off the front or back, not both and tall enough to contain the holes.
After making sure the bottom and the registration edge are square I lay out the hole locations. If it's only one cabinet, I drill holes the right diameter (1/4" for example) for the shelf pins on the drill press to make sure they're square. Set the jig in the cabinet, clamp it in place and drill away.
If you want one with more longevity drill the holes in the jig to take 1/4"-20 T-nuts. After inserting the T-nuts run a 1/4" twist drill through each one to remove the threads. This leaves decent bearing surfaces to keep the drill bit straight and won't wear as quickly as plywood.
Bob Lang
Charles Sharp
>I have a Rockler jig and it works well.
For 1 or 2 cabinete I'd get a piece of peg board and use it to drill the holes.
NickB
>I'm with these guys, except that I've made a 32mm spaced jigs (so you can use the various and sundry 32mm system gadgets out there-I've done a lot of custom closet inserts, and being able to use the 32mm system closet rod holder is a very good thing), but peg board is really easy if you don't want the 32mm spacing.
1/4" hardboard, drilled on a drill press, combined with a self-centering drill bit (replace the twist bit with a brad point) does the job for me. I'd only do one set of holes, and flip it to do the two sides (and the front and back lines of holes). My closet jig is 4' long, with 32mm holes spaced 25.4mm (well, 1" really) from the edge. I flip it front and back to do the various rows, and use some pins I turned on the lathe to register for lines of holes longer than 4'.
Hope this helps,
Nick
Easy and Cheap
Terry Alexander
>I just use a scrap piece of pegboard. The guide holes are there and they are perfectly spaced. Didn't cost me anything (since it was scrap) and I have used this "jig" many many times....flawlessly.
HTH
Terry Alexander
Lee Gordon
Lee Gordon
>Mine is a version of the one Norm built on New Yankee Workshop a few years ago (and that just ran on DIY network last week). I didn't have the video handy when I made mine but I downloaded a picture of another person's version (quite possibly got it here at Wood Central, but I don't remember for sure) and used it as a guide to make my own. The holes are 5/8" in diameter (to be used with a plunge router equipped with a 1/4" spiral upcut bit inside a 5/8" collar) and are spaced 1 inch on center. There's a 1/4" hole on each end, also spaced 1" on center from the adjacent holes, so the whole jig can be slid over to extend the run longer than the 3' length of the jig itself. (The lynchpin you see on the left side of the top view plugs into one of the 1/4" inch shelf pin holes to facilitate registration.) The fence, which you can see on the underside, is attached with carriage bolts that run in slots parallel to each end of the jig.
Re: Easy and Cheap
Russ Babbitt Jr.
>I've done the same thing. Works great.......
Re: Easy and Cheap
robert davis
>i do also
