A55 Smoothing Plane
inside radius cutting of bowls
Dale Moore
>Im a fairly new woodturner although I have turned some good bowls. My biggest difficulty is cutting an inside radius in the bottom od a bowl especially a deep bowl. It seems the deeper I get the more chatter I get and also I have difficulty in getting rid of the button in the center if the bowl
I need help
Thanks
Dale Moore
Re: inside radius cutting of bowls
Bill White
>Mark, Try posting your question on the turning section. I'm sure you'll get some good responses.
Bill
>Post this on the turning side and you will get more responses. Most people have trouble with the inside of bowls because of the shape. A bowl that has a long continuous curve will be much easier than a bowl that has straight sides and a more or less flat bottom.
What happens is you are turning down the side and you reach a point where you can't stay on the bevel of the tool and continue to the bottom. consequently you get chatter and possibly kickback.
Another problemwith that shape is that it's difficult to get the tool rest close so you have more tool hanging out over the edge which also leads to vibration and chatter.
The solution is to use 2 different gouges with different grindes. Most bowl gouges come with about a 65 degreee front bevel. For steep sided bowls you may need one that is ground about 75 or 80 degrees.
Before changing gouges or your grind try rotating the flute up or to the right and see if that helps. Because most bowl gouges change the angle of the bevel from front to side you can sometimes rotate the gouge a little and maintain contact with the bevel throughout the cut. Usually rotating it so the flute points toward 12 or 1 oclock will solve the problem.
