OT--- toughest paint for lumber rack?
Dave Morris
>I've had a Rack-It lumber rack on my pickup for years. it's a great, strong rack, but it's suffered the abuse of tie-downs, rebar, lumber etc., scratching the paint down to the metal and the resulting rust in those spots. Hey, it's a rack, it gets used. ;-)
It's off the truck for the moment while the truck bed gets a coat of Line-X. Is there a REAL tough paint I can easily spray/brush on that will stand the abuse better than the "Easy-Fix Option" of Rustoleum/Krylon/rattle-can paints? I thought about having the rack sprayed with Line-X as well, but that seemed like it would only be tougher to repair in the future, as pulling rebar off the rack would probably file it down just like it does paint.
I've held off painting the rack until now because it surrounds a white camper shell and spray-painting a black lumber rack just didn't seem worth the risk. But now that everything is off the truck and separated, well, the time is right.
Dave--- who figures he's gunna go through a lot of ROS discs/sandpaper sheets and/or navel jelly this weekend to cut through the rust
Re: OT--- toughest paint for lumber rack?
Try Eastwood.com
Ray Thompson - Middletown,IN
>They have some automotive stuff that will work. I think the name I bought was POR 15 or something similar. It seems to be an epoxy type of paint. Do not get it anywhere you don't want it, including yourself. Once you open the can use it all and use a disposable brush. It's hard as nails when dry.
Ray
Maybe over the top
Neal in San Jose
>I have some "family heirloom" (AKA hand-me-downs) wrought iron patio furniture that I had sand blasted and powder coated by a local company. It looks great and is wearing very well. It wasn't cheap, but not out of the question, and I didn't do any sanding, spraying, etc. However, it may look so good, you want to trade the truck in!
Re: Try Eastwood.com
ScottS
>My barber used POR15 on an old Ford F100 he was restoring and has been extremely happy with it. He says you can brush it on, it levels nicely, and it cures to an extremely durable finish. You can buy a starter kit for around $17-18 if you want to give it a try without a big investment. The only problem I can see is that it's only available in gloss and semi-gloss; no matte. I bought the starter kit to try on some furniture I've been welding up, but haven't had a chance to use it yet...
Dave Morris
>Ray and Scott, Thanks. Gunna go look at their web site.
(time passing whilst checking Eastwood online)
Okay, I'm back. Hmmmm... Eastwood has this stuff called "Rust Encapsulator" that claims to be better than por-15. Either might be available locally at an auto-paint supplier unless Eastwoood's products are only available from them. I'll check into it for purchase, but have you ever heard of the Rust Encapsulator stuff?
Dave--- thinking that working with this gunk could be as messy as Wet Patch roof sealer...
Re: Maybe over the top
Dave Morris
>Yeah, it would look GREAT. So great, I'd be afraid to use it. I'd probably have to drag some rebar back and forth over the rack crossbars a few times just to get over that "first scratch" syndrome. ;-)
Dave--- who was told by an old craftsman, after spending many long hours building his "ultimate" workbench that he was soooooo proud of-- "Now go drip some oil-base stain on the top and hit it a couple times with a hammer. After that, you won't be afraid to use it like a workbench."
Yea, you're right
Neal in San Jose
>That powder coat made the '50 vintage furniture look so good that everything else suddely started looking a little tired.
Yes, sorta
>Other companies have similar products. For example Gemplers.com sells a rust product. I think they chemically bond with the rust and seal it off. Don't quote me on that and no I'm not a chemist nor did I stay in a Holiday Inn last night.
Ray
Bart Castleberry
>Nothing you paint/spray/brush on is going to stand up to rebar sliding across it. Looking for something like that is pointless.
If you really carry that much rebar, just repaint the rack with whatever's good enough for the weather, maybe tractor supply's tractor paint? Or something pretty weather resistant. Then put something on top of the rack, stainless steel, aluminum, PVC pipe, wood, PVC trim, corian scraps... whatever-- to get worn by the rebar. Glue or bolt it on. PVC pipe could be cut to slip over, and metal can be had in U channel and angle. Angle would be my choice. U might hold water between it and the rack.
