>Hi guys - I'm building an oak staircase & am at a quandry. I need a durable finish, but it has to dry fairly quickly, as I can't tie up the main staircase to the house for a week while I wait for the finish to dry. Most rock hard table top type varnishes that I've used in the past dry painfully slow. I'm going for a semi to gloss look. I would prefer to spray, but could brush. Finishing is my nemesis ... just don't enjoy it - so any advice would be appreciated. Thanks
John
Re: What type of finish for custom oak staircase ?
Howard Acheson
>First, let me say that oil based varnish will become tack free in 6 to 8 hours but that is just the thinner evaporating. The curing process takes 3-4 weeks to develop full strength, abrasion resistance and adhesion. Waterbased will become tack free with an hour but, it too, has a long secondary cure that lasts for a couple of weeks. Oil based and waterborne poly varnish are the two most used floor finishs as they both provide superior durability. The oil based will last longer than the waterborne.
All that said, there is no finish that can be applied that will develop full cure in 24 hours no matter what the advertising claims. Keep in mind too, that you need to apply at least three coats allowing adequate time between coats for the finish to dry. Just the application is two days minimum.
What I suggest to you is to find a time when you can give it at least 48-72 hours. After that, cover the stair with some pieces of carpet for a couple of weeks. Be very careful if you do this as the carpet may slip and cause an accident.
John Snyder, Poconos PA
>Thanks very much Howard for the advice. I may actually finish the stair treds before I assemble it based on your advice - I think it would be easier all the way around...
