Question for Festool Ownters
Roger
>I am going to purchase a Festool 75EQ Circular Saw and would like to know if the Fein Turbo III shop vacuum will interface with this saw, or will I have to purchase on of the Festool Vacs? If a Festool Vac is required, which one would you recommend: CT22E, CT33E or the CT Mini?
TIA
Roger
Re: Question for Festool Ownters
Steve Roxberg
>You can purchase a Festool hose that fits both your Fein and your saw for around $50.
You can also use some adapters that Fein sells. The plastic ones with several steps, you just cut it at the correct size. Woodcraft sells these.
I have both a CT22 and a Fein Turbo II, I like the Turbo II better as a vacuum. I got the CT-22 for a really good price, and it does work well with the Festool items.
>I can't answer the Fein question. I have the CT22 and like it a lot. I think the extra power helps and this seems to have plenty. I'm sure the CT33 is great but maybe more than I would really need.
The other thing... I was looking to buy the 75EQ too and got some good advice here that the 55EQ would be plenty for my needs. I took that advice and found it to be true. I use mine a lot for cutting sheet goods but I do also cut hardwoods. I find the 55EQ to be plenty for what I do. Maybe it would be for you too? If so it would save you some money.
Tom
Dave Arbuckle, Plano, TX
>Like Steve Roxberg, I use a Festool hose in my Turbo II. If the Turbo III has the same connection as the II, the Festool hose plugs right in.
The connection to the tool is an odd, kinda oblong rubber dingus, that's in no way similar to the Fein's round connector.
Roger
>Steve, Dave & Thomas,
Thanks for your input, I think I will purchase the 75EQ as the differential cost is only $120.00 and I would be rather upset spending $430.00 and finding out that I could realy use the larger saw. As you suggest, I will purchase the Festool hose only and keep my fingers crossed that it will fit my Fein Turbo III. If not I guess my next purchase will be a Festool Vac. Again thank you for your responces.
Roger
Todd from San Jose
>Hi Roger,
I've had the same dilemma, but chose to sell my Fein TII and get a Festool CT22. Here's why:
1. I've owned the Festool plunge saw for a few years, and love it. I've been just jamming the Fein hose into the saw's boot, which doesn't work worth a hoot. I was about to buy an adapter, but read a number of posts that recommended to buy the Festool hose. Well, this hose is around $90.
2. I just bought the 150/3 sander, and a lot have commented that it's really nice to have the variable suction adjustment that the Festool vacuums have, for Festool sanders. Too much suction causes the sander to suck down on the work, vibrate, and can leave swirl marks. Some have made some type of a bleeder valve for the Fein vacuums to remedy this, but I prefer to just get the Festool vacuum to solve this.
3. I also have a Domino on order. So I figure that now I'll have 3 Festools, it'd be nice to have the mating vacuum with no adapters or mods.
4. You can stack your Festool tools right on top of the vacuum, along with the Festool tools and hose garage. It's a small thing, but helps neaten up the shop nicely.
I'm going to seel my beloved Fein TII in the next week or so.
Todd
