Changing Drum Sander Rolls???
Carmen Basile
>Helpful Friends,
I'm in the market for a drum sander, a Performax, but I can't get any information from the Manufacturer's (Jet?) website. I'd love to be able to get my hands on a download-able user's manual. I don't understand if it's easy to change from one grit to another, and quickly. Also, is Performax the best brand to get? What about other brands? Are any others more durable, easy to set up, easy to callibrate left to right, easy to change grits, and able to do quickly? Do any manufacturers have a setup that would allow one to simply change from one wrapped drum with one grit, to another wrapped drum with another grit?
The one I'm eyeing is the Performax 649005K. Do any of you have this one and how do you like it?
I would appreciat any opinions.
Thanks to all in advance.
Re: Changing Drum Sander Rolls???
mike from American Sycamore
>I have sold dozens of the 1632 in my career. It is a wonderful machine for the hobbiest and does have a learning curve. It is easy to operatre and changing paper is a breeze. Good luck and Build with Confidence!
Mike
DocJim...Fayetteville, NY
>We have the same machine without the cabinet in our shop at Habitat for Humanity. It does a good job and there is a learning curve. We make our face frames and doors out of cherry and the wood burns and ruins the belt really easy if you try to take off too much in one pass. The belt is easy to change...it is a long strip of sandpaper wrapped by hand on the drum and held by spring clips at each end. It takes a few minutes to change the paper.
Although I have no experience with other machines for comparison, I am very satisfied with this particular model.
Jim
IMPORTANT!! Stop the machine first!
Forrest Addy
>I have a 1632 and like it. As others have said there is a learning curve. I find the machine works best on coarse and medium grits With 80 and 120 being my "favorites". Keep the sand paper fresh, clean and sharp and the work moving as fast as possible to avoid the burning. Also use light cuts.
It is a hobbyist machine, not really great for production.
Changing the paper take two or three minutes and is about as complicated as changing a table saw blade. I do find the clip near the motor to be a PITA. Requires a bit of a knack to hold the clip up and insert the end of the strip and release the clip in such a way that it grabs the strip and pulls it tight. Not enough of a problem to cause me to hunt down one of the little wire holder accessories that is supposed to help in the process, though.
It had not occurred to me that interchangeable drums would be a good idea. I think the mechanics of supporting the drum from one end only and keeping that very accurate would make that impractical.
I have an older machine I bought used and have not made any adjustments to make the drum parallel to the table, so I can�t answer that. I did change the drive belt on the table and found getting it to track tedious, but I understand that has been changed on newer machines.
Carmen Basile
>Thank you all!
A few more questions
Is Jet the manufacturer? If so, How can I access the user mauals and warranty information for these machines?
Thanks again.
Gee. no sense of adventure ;-)
Dan Donaldson
Fish eating fish
>Jet bought Performax, then WMH Group bought Jet.
Who MAKES the machines? Beats me, but it's likely different than who was making them 12 months ago, and different again from who will be making them in anothe 12 months. Then again, it could be the very same people who have been maiing them for the last 10 years, they just get a paycheck with a different company logo on it.
Happy Woodworking!
Re: Fish eating fish
>I think if you search the WMH Tool group site, you should be able to find a way to print the manuals. I read here the other day that WMH/jet sold the Performax name and that someone is now making (Junk?) tools under that name. I think my machine is pre-Jet purchase and American made, Unlike the ones today. Jet is still makeing the machines (or somebody is making them for Jet), but they will no longer carry the Performax brand.
Have you tried searching for "Performax"? I got stuff you would be banned from discussing in polite comapny. Pretty funny thouhg.
Performax 649005K *LINK*
Hoa Dinh in Alameda
>I see Performax 649005K is listed on Amazon. There are some reviews there.
I can't find the manual for 649005K. But it is similar to 649003K and 649004K (see link below).
-- Hoa
Performax 649003K/649004K Manual
