O.T. Hydraulic jacks for sport utes
Alan Tolchinsky
>Hi All,
I want to rotate the tires and inspect the brakes on my sport ute but my old hydraulic jack just doesn't lift high enough. Do they make jacks that lift higher? Or has anybody here built a platform to put their old jacks on to raise the height? Any ideas greatly appreciated. Alan
Re: O.T. Hydraulic jacks for sport utes
chunka wood?
John in New Mexico
>Done that before. A bit of denting, so don't use a prize walnut bowl blank :-0
Cupla 4x6 cutoffs under the jack ...
Dave Morris
>... work fine. Just be careful, if your jack is the type on wheels, that it doesn't roll off the wood as you lift the SUV. On long trips, I carry my floor jack and a couple 24"-long cutoffs just for this very purpose, since installing a Over/Under axle kit on our camp trailer lifted it's frame above my jack's reach.
Or just place a sturdy piece of wood on top of the jack's lifting pad and lift away. This will also work well if your jack is the type without wheels.
I've done it either way, depending on what jack was handiest at the time. Both methods work to take up the extra space your jack won't fill.
Dave--- off work today to schedule getting Line-X sprayed on his pickup's bed and it's "Rack-It" lumber rack as well
clarification...
Dave Morris
>Make that read "Cupla 4x6 cutoffs PLACED SIDE BY SIDE under the jack" since I didn't specify that in my previous post. This gives the jack a wide enough base to be stable. I would not recommend using a jack on multiple "stacked" pieces of wood. Just too many layers to be safe, in my opinion. And don't do any work on the vehicle using the jack "alone" as support. It pays to be safe.
Dave--- who always rests the truck/trailer on a *stable* large-base jack-stand while working on the vehicle
Re: O.T. Hydraulic jacks for sport utes *LINK*
Hoa Dinh in Alameda
>Alan,
Buy a floor jack that has the height capacity. I have one similar to the jack in the link (bought 15 years ago, before I knew about HarborFreight). It has 20" lift. I think that's good enough for most SUVs.
Whatever jack you have, don't trust it. Get a pair or two of jack stands to support the vehicle. I normally place the wheels just removed underneath the vehicle as a pre-caution.
-- Hoa
THREE TON LOW PROFILE FLOOR JACK
Rich S
>Yes, they make floor jacks for sport utilities that have a higher lift...you can buy them at almost anyplace that sells hydraulic floor jacks...Walmart, Sears, etc...they are literally a couple $$ more and generally come in carrying case...plus they typically have a fast lift/slow lift system, meaning that it takes two or three pumps to lift it to hit the axle and then when it takes on load it starts to pump like a regular jack (moving a 1/4 inch or less with each pump)...I carry one in our Excursion and another in our Super Duty since both have a substantial distance from the ground to the axle and I wanted something a bit easier to use, something with a bigger footprint, and something with more capacity than the stock jacks that came with the trucks which are a post type hand cranker which suck to use when a truck is loaded (you'd think for $40,000+ for a new truck,$25000 for a couple year old truck, that the manufacturer could send a better jack than they do.....plus the trailers we tow have higher ground clearance and unless your carrying a 4x4 chunk of wood your almost totally screwed unless you have a taller floor type jack or a taller bottle jack....if you don't want a floor jack then purchase a decent sized (5 ton or so) bottle jack and that will do just fine too...the weight isn't an issue, but the height is..
Jack blocks
Tom Dunlap
>Having blocks that are rectangular gives a lot of flexibility. 4x6 is a nice size. A few slabs of 2x6 give good support.
I saw that a company makes a hydraulic jack that is built into a jackstand. The hyd jack would take the unit up then a cross pin would lock the center section in place. Clever idea! They weren't too expensive either.
Alan Tolchinsky
>Thanks guys for all the ideas. I think I'll try the 4x6 block method and see how it works first. If that doesn't feel right I'll go out and buy a jack with more lift height. Thanks a lot for all the great ideas and appropriate warnings.
Gary Evans Tallassee, TN
>Hi Alan,
I just did this today with my Explorer to replace the radius arm bushings.
I used a "cribbing" of 4x4 and 2x6 pieces with a piece of 3/4" plywood on top. I just made sure that the wheels were sitting right on top of two cross-pieces. It took 2 long bottom pieces of 4x4 and two crosspieces of 2x6 to get the height I needed to get the wheel off with the little two-ton jack that I have.
If this doesn't make sense, I'll take a picture tomorrow so you can see what I did.
Gary
