Help with forum display
Mike Farinella
>I installed IE 7.0 and can't seem to get my split screen back. If I select an item, it opens up a new window. I've tried changing "set preferences" to no avail. Any suggestions?
Mike Farinella
Tabs
>For the fisrt few days I hated the Tabs, now I can't live without them. IF you're not used to them it takes a while to get used to.
You can customize the way tabs work.
Tools > Internet Options > Tabs > Settings ....
You can choose the way new windows are openeing (in a new window or as a tab in the exisitng window, as well as other things).
Happy Woodworking!
Thanks Mark but ...
Mike Farinella
>I tried a lot of things; restarted the PC numerous times, even disabled Tabs, but when I select an item, it still opens a new window. I want my split screen back!
I wish someone would figure this out
>You're about the tenth person who has reported this behavior after installing IE7. I don't know if others are also having this problem. Maybe they can tell us how they handled it. (Any help here, folks?)
My theory is that the new browser thinks our frame setup is some kind of popup or something, or maybe it can't or won't parse "IFRAMEs", which are the little windows that our banner ads are displayed in. So, it could be a matter of tinkering with the security settings. It could also have something to do with the cookies. If you haven't deleted your WoodCentral cookies, you probably should try that first.
I personally have not installed IE7 so I'm not able to be much more help than this for now.
Re: I wish someone would figure this out
Kris Lasure
>Did you try the add/remove frames link at the top of the message boards?
I have IE7 and have no problem with the split page.
Try switching to Mozilla Firefox
Alan Young
Mine works "fine" too
>But perhaps my "fine" is not the same as other people's "fine".
When I switched to IE7 in December, and then customized the way tabs were processed, WoodCEntral worked identically to IE6.
In fact I have several other computers that have IE6 and they are all working the same way for Wood Central.
Perhaps it's a combination of your WoodCentral preference settings, your IE options and the way you expect it to work.
Here is the link that I have bookmarked:
http://www.woodcentral.com/newforum/msgset.shtml
WHen I come here I get 3 frames all on one window. Tall skinny window to the left with the brown WoodCentral menu (red logo on top, yellow list of links, all on brown background).
THen the right side of the screen I have two white frames on top of each other. The top half is the list of all the postings, and the bottom half is the actual contents of a particular post.
When I type a reponse, the two right frames become one frame, then when I post it, I get the horizontal split back and have the top half and bottom half seperate again.
The left side menu never goes away.
I have a large high resoultion monitor and it works best like this.
Happy Woodworking!
Joy at last!
Mike Farinella
>As I mentioned before, I disabled Tabs, rebooted Windows, launched WC again, and the same thing happened (opened a new Window). But alas, I launched WC again and it worked! - my split screens are back! Yippee!
Thanks everyone for the help.
So, what's the lesson??
>I'm glad it works, Mike, but what did you do besides relaunch WoodCentral to make it work? Anything?
Microsoft makes me crazy.
Beats me ...
Mike Farinella
>Just relaunched WC a second time and it worked. Go figure.
Re: Thanks Mark but ...
Howard Acheson
>Go down to the bottom of the window with your cursor. When it changes, grab the line and draw the bottom up. That will reveal the split screen I betcha.
Lee Gordon
>I'm using IE7 and have no problem getting frames. I just went to the "Set Preferences" link at the top of the main page and scrolled down to the radio button that says "Frames" and selected it and Bob's your uncle. Ironically, I don't generally like frames but I guess I'm used to having them here so I keep using them.
I logged into......
>I logged into your computer, Mike, and fixed your settings.
No, no, no.... no thanks are needed. I was happy to help out.
I didn't touch anything else on your computer.... I swear!
Happy Woodworking!
WoodCentral Cap!!
MountainMan
>Hey Ellis!
I receivd the nice burgandy cap in the mail today - thanks man!! Very nice!! I will take it on a photo safari soon!!
Regards
The MountainMan
Wear it in good health
>...and watch out for grizzlies. :-)
