drawers
Danny - Hermann,MO
>I'm in the process of making kitchen drawers for my brother. Was wondering what the choice of wood that is used for the bottom of the drawers. What 1/4" product seems to work the best?
Thanks for the help!
Danny
drawers
Danny - Hermann,MO
Danny
Re: drawers
Bill Tindal, E.TN
>I like to use birch plywood for this task. I think it looks sharp and when finished it is nonporous so it doesn't soak up spills should they occur.
Re: drawers
Carol from AZ
>From a woman's point of view.
I like double sided white Melamine. No liner needed. Easily cleaned. Looks great!
From a woodworker's point of view.
Inexpensive, great yield out of 4 x 8 sheet, and no finishing required. I finish the ends and sides before assembly. I just tape of the joint area to be glued later. Also glue squeeze out pops off easily.
So easier, cheaper, better looks and long term functionality. Works for me!
Re: drawers
>I agree with Bill, birch plywood.
NOT masonite, either tempered or regular, 1/8 or 1/4. Stay away from it, It sags over time and looks awful. Easily damaged by water.
Carol has a good idea about the white melamine if the core is strong enough to resist sagging. Just don't know, no experinece, but it sounds good.
quality
Joe Piotrowski - Chicago Burb's
>If the rest of the drawers are nice wood, well constructed you have to finish it off with a quality bottom.
I have been looking at getting new kitchen cabinets and from the cheapest wood facing to the most expensive all had a plywood bottom.
Re: drawers
J Runchey
>FWIW I made my workbench in 1962 using 1/4 tempered masonite in the 8 drawers which have held up very well, no sagging whatsoever. I also made the top with 2 layers of 3/4 plywood with a top layer of the same masonite. I just replaced it with a 2" maple top about 5 years ago. Maybe the masonite of today is not equal to the masonite then.
I like to try and match
Mike in Paradise
>the finish that is on the side of the drawers using a veneered plywood.
This drawer is from a dresser in a bedroom set that I made.
Great idea Carol...
John in New Mexico
>I wish I'd thought about it before building our drawers :(.
We used 1/4 baltic birch. Maybe next time I'll glue some laminate to it- best of both worlds and still no finishing!
John
Re: drawers
Tom Stockton
>For kitchens 1/4 prefinished ply wood. for larger drawers near the stove tht will have pots and pans in them 1/2" prefinished ply wood.
Tom
Re: drawers
Jim Dillon
>Danny,
I went the route that John suggested and glued laminate (color chosen to compliment the countertop) to both sides of quality plywood. For deep and large pots and pans drawers, I used 3/4 inch ply but for other drawers, I used 1/2 inch ply. I also did the cabinet shelves in 3/4 inch ply with laminate on both sides and a wood trim edge. Sure easy to clean. But it is more costly and time-consuming to make. Good luck.
Jim
Re: drawers
Carol from AZ
>Been doing that way for years, Barry. In the shop some drawers have a considerable amount of weight and there is no evidence of sagging.
And guys, just because some high end cabinet maker has been using plywood for years doesn't mean its the best product. I humbly suggest you discuss this with the major user and upkeeper of those drawers whether they want to use drawer liner or simply have a nice clean white surface that just takes a damp cloth to keep clean.
Who knows? They be so taken with your thoughtfulness, that you can get a new tool out of it, because you are such a good woodworker. :)
Just my 2 cents.
drawer liner?
>what's that ;)
maybe Plywood with laminate would be good good. I will try that on something.
I just prefer it not be MDF. I know as a person who butchers projects that no matter what the material used, has no reflection of the skill. unfortunately I believe the common person would not make that conclusion if they see some particle board. they would rather save money and go buy it at Ikea or some dept store.
Re: drawer liner?
Carol from AZ
>Hi Joe,
Double sided Melamine does have an MDF core, however, it is never seen. The edges are trapped in dadoes of the sides and ends. The surfaces are a clean white, easily cleanable smooth pre-finished surface. Other colors are available, but at a premium and on special order. Any sheet goods supplier that trades with cabinet shops will have pallet loads of them. Very reasonably priced, on a par with plywood plus the finish material. The overall time spent is where the big savings are.
Just my 2 cents, based on a couple hundred drawers. :)
thanks for the tips.
