>I'm building some bookcases using oak plywood (grade b-3). I have taped the cut marks, used a panel blade, thin blade but still have "blow outs". I don't want to waste any more expensive wood, how is the best way to cut this finish grade plywood?
>I don't know your specific problem but it is essential to have a very sharp blade. I don't have this problem, so it can be done. I use a Freud cross cut blade. It has lots of teeth, maybe 80.
Could you tell us a little bit more. Is the chip-out on the bottom of the plywood, or on top. Are you using a table saw or a circle saw to cut the plywood.
Assuming you are using a table saw: my first thought is your blade clearance through your saw's throat plate is to big. Make a new throat plate and raise your blade up through the it. Keep your plywood in good contact on the table saw while sawing. Both of those methods will support the plywood next to the cut and will lessen the likelihood of chip-out.
>If the plywood seems especially prone to tearout, I score it with a knive before cutting. I use an 80 tooth plywood blade and a zero clearance insert.
>When we tested sawblades for the magazine years ago, we found that some blades gave consistently perfect crosscuts in oak plywood. We chose oak plywood because it is so notoriously prone to chipout.
I haven't participated in any blade tests recently, so I'm not going to recommend a particular brand of blade, but you want an ATB (alternate top bevel) or Hi-ATB (a steeper top bevel) top grind and 60 or 80 teeth (assuming a 10" tablesaw).
>I agree with the others. Sharp crosscut or plywood blade, zero clearance throat plate and score the cuts.
I actually have acceptable luck with my Forrest WWII blade, but I don't make many cuts.
Two other things. Borg quality plywood (made in China?) seems to be more troublesome that its (more expesive?) American counterpart. May have something to do with the glue and the thickness of the veneer. The plywood is not cheaper if you leave half of it in the scrap bin.
I have trouble with the tape. If the glue/veneer is marginal I find the tape doesn't help much and may hurt in the sense it lifts off any loose veneer after the cut. Maybe that veneer woudl have fallen off anyway but it sure seems the tape does more harm than good, sometimes.
>I have the same experience with tape and "home center" plywood. The best way I found to deal with this (before going to a better supplier and paying for a noticably better product) was to score the cut line with a new utility blade. If I did not score the tape simply pulled off any loosened veneer and made the problem worse.
>Sharp carbide blades with lots of teeth and alternating teeth ground at 45 degree angles. I have a Forester blade. Cost about $110. Can cut cross grain on a 4' piece of plywood and get only a couple minor splinters. Use it only for plywood cutting to reduce it's use.
You've gotten great advice. I've had good luck with the Forrest Duraline HI-AT plywood blade and a newly made TS insert. But it is expensive and if you just bought a new blade, you likely don't want to rush out and buy another. Try very lightly scoring - just enough to break the surface of the veneer - the bottom side (where the tear-out is likely occuring) of your plywood with your plywood blade. Then do your full cut. Might work. Good luck.
