OT: Concrete Driveway Repair
Mark Kauder, Phenix City, AL
>I have a concrete driveway that is about 35 years old. It is about 40' long, and was poured in 3 sections. It has good expansion joints that are pretty much still there. The drive way goes down from the house, with a drop of about 5'. My problem is that I also have a couple of huge pine trees in my yard. They are in a planter that is about 7'x7', and over the last 12 years the planter has slowly been destroyed by the roots of the trees. That is by way of explaining the problem with the driveway - the roots. Right at the junction of the two lower sections of driveway, the roots caused the driveway to buckle and crack, it was that way when we bought the house. Again over the last 12 years it got worse, and I am now at the "I have to fix this now) stage. The broken section that I want to repair is about 2/3 in the upper section, and 1/3 in the lower. The whole section is D-shaped about 8'long and 15" wide - longest being along the length of one side of the driveway.
I want to remove the broken section, cut the root out, and back toward the tree a few feet and then pour concrete to repair.
OK....finally here are the questions.
1) Any suggestions on how to re-enforce the repaired section?
2) Is there a decent (read relitively easy) way to tie the new and old section together for strength? (yes, someday I will have a new drive way poured).
3) How long should I let it cure before I can drive one it?
Mark
Re: OT: Concrete Driveway Repair
Ray Thompson - Middletown,IN
>Get a concrete saw and cut out a rectangular section and remove the offending concrete. Get rid of the root problem, form and pour a new section. You will need expansion material along the cut edge.
If you want to tie the new and old section together cut some rebar about 12" long and drill a horizontal hole 6" into the old section about halfway between the top and bottom surface, expoxy the rebar halfway into the hole and half sticking out into the new ready to pour section. Put in the expansion, tie wire mesh to the rebar sections and pour. If you plan to redo the entire drive at some point I probably wouldn't put in the rebar . Cutting the roots will probably cause some problems with the trees but you can deal with that later.
Ray
Thats about the size of it.........
Scott in Eastern Iowa
>.......I agree with most of Rays advice. He must have some concrete experience in his bones?
I dont know to what extent you'll need to remove the trees root system ,but the trees death or decline may be a very real scenario. You may have to deal with the trees removal eventually, but water it well into the fall and it may just make it.
You will know in 1-3 yrs AFTER this concrete replacement if you saved it.....
Scott
Re: Thats about the size of it.........
>Scott - you said what I was thinking about Ray. Thank you both. Good advice and easy to understand. You are right, Ray, I don't think I will bother with the tie in to the older concrete. Scott, I am less worried about the trees. Thought I would love to have them gone from a yard cleanup point of view, the kind of define the look of the front yard, and the house would look very different. Since we get so much rain down here, the Pine trees tend to build pretty extensive root systems that do not go super deep, in part also because of the hard pack clay. I have seen roads cut, with nearly 1/2 of the diameter of roots cut through, and the trees doing well many years later. Bark beetles are a bigger threat, but thanks for the thoughts about that, certainly worth thinking about.
Neither of you mentioned it - How long to should I let it cure before driving on it. The drive way is wide enough to avoid this space as long as necessary, but what is necessary.
Mark
Oops, forgot that part..
>I would avoid it for about a week. Also keep it sprayed with water for about that long. Also, don't put any salt on it for at least a year, preferably longer.
Ray
Re: Oops, forgot that part..
>Yep, Ray knows his concrete. What he said.
One minor suggestion. If you want to dowel the concrete together, that eliminates the benefit of the expansion joints. You can drill and epoxy them into the old concrete and then slip a piece of plastic pipe over the part that goes into the new concrete to serve as a slip joint so it will help keep the two slabs level but allow them to move. If you can find it use epoxy coated rebar so it won't rust and expand.
Chrispy
>I too have a house that I bought new some 35 years ago. At the time that I bought it there was a small piece of concrete (2ft by 9inches)that had been damaged by a tree root. I was advised to remove the damaged concrete, to clean the edga of the reaminder and to coat it liberally with Contact adhesive (Yes!). I was somewhat sceptical but did it. It is still there after 35 years!
Chris
Rebar
>I cutout and repoured a small section of walkway. About 30" x 6".
I compacted the clay underneath well (so I thought) but after a few years the section sank a bit. It's been about 8 years and it's sunk about 3/8" inch. Nothing too major to repair because of it's small size, but next time I do it on any size, I'm going to use rebar or something to help keep it from sinking.
Happy Woodworking!
Contact Adhesive on the root?
>Did you apply the contact adhesive to the root, and then pour new concrete over that?
Happy Woodworking!
In defence of trees
Tom Dunlap
>Be VERY careful before cutting roots off. Removing any of the larger, first order, roots of any tree can lead to decline, death or destabilizing. Trees can be quite tolerant of root loss if it is done carefully. But...there is a limit.
If you'd like a long distance consultation drop me a note. I'll help as much as I can. Another possibility is that I might know of a knowledgeable arborist near you.
One option would be to plan for an possible future root issues but forming up a sacrificial section near the tree's roots. As the root grows in diameter it would push up only a small section instead of a larger panel.
Roots get blamed a lot for poor construction. it would take too long and too much space to go into root physiology. But...the main thing to remember is that roots need water, air and nutrients to grow. If they can't find any of those three they grow elsewhere. There is research that has proven that proper construction will lead to much reduced 'damage' by the roots. Roots and trees have few vocal advocates so they get blamed for a lot of things. No wonder the Ents are so sad. Besides not having Entwifes around for years they've been abused a lot.
Tom
Re: In defence of trees
>Tom,
If it is a large diameter root, and say only 1/4 to 1/3 of the diameter (this is likely a short section causing the problem) is causing the rise that displaced the concrete, can I remove that portion of the diameter of the root, and not completely damage the viability of the root/tree?
Mark
Re: OT: Concrete Driveway Repair - Ray?
>What would be the short term (several years) viability of a removing all the parts of the cracked area, the largest being about 12"x24", removing the offending upheaveal, compacting the soil, laying down either sand or ABC gravel, and then replacing the parts and affixing them with some sort of adheasive?
Mark
If it is that small
>I would consider getting some asphalt hot patch and a tamp and smoothing it over. With time it will heave and crack but just heat it and re-tamp and smooth it back down. I'd bet you could call a paving company, take a 5 gallon bucket and fill it cheap enough.
Ray
Re: OT: Concrete Driveway Repair - thanks
>thanks to you all for the great input.
I don't know what I will do, yet. Probably will not until I am standing over it with pick and sledge, but now I have more options.
thanks again
mark
