Drywall Again ....... Corners This Time
Joe Burke
>All the advice I got last time around was well worth having, and after thinning the mud my skim coats worked well enough. Eighteen patches in one bedroom and I still missed two!!
Now .... every inside corner is cracked from top to bottom. I'd thought I'd clean out the corner ..... retape and remud. I wonder, however, if that's not overkill. Anybody I've asked about this type work has said I could expect the cracks to open again no matter what I did. Given that, maybe just another coat of mud to fill the crack as oppossed to tape and extra mud to cover the tape ..... which may crack anyway?
I'd say any advice as to how to handle the inside corners would be appreciated.
Re: Drywall Again ....... Corners This Time
Larry Clinton At Frankfort (Central)., Indiana
>Hi Joe, I am sure no expert at drywalling, so take the advice for what its worth. I have always had the same trouble as you with the inside corners. When I built my shop, I bought the metal corners with the tape stuck on and put them in all inside corners. I still sanded off about 3 lbs of mud for every 4 applied, but the corners didn't crack. I did become much more proficient after finishing my shop - learned to apply thin coats and not sand so much. Drywall finishing is real low on the list of things I like to do. Just above running my thumb across the jointer. I would rather scoop out a chicken house than finish drywall. (and I've done both)
I have never had a problem with inside
Mike in Paradise
>corners splitting.
If you have a crack I would re-tape and fill. If you just cover it over with mud it will most likely just crack again.
I have an inside corner trowel that works well for those corners. I get a good line down the corners and then worry about cleaning up the edges on the sides one it is all dried.
Re: I have never had a problem with inside
>Joe, If you have hair line cracks down the corners and no puckering of the tape, I would consider caulking them. Get some excellent quality caulk that is "Paintable" and run a very small bead down the corners and smooth it into the corner with your finger. A very small amount, just fill the tiny crack. You might wet your finger with slightly soapy water.
If the tape has pulled loose or puckered or is torn, all bets are off. You can retape, but if it cracks again you may have some other problem.
Cracks often occur in corners becasue houses apre built "wet". The lumber gets rained on and the hosue is finished and then it drys and cracks. Hopefully, once these cracks are repaired, they won't reappear.
Lee Gordon
Lee Gordon
>If you're going to put a fresh coat of mud in the corners anyway, I'd reinforce them with fiberglass tape.
Ray Thompson - Middletown,IN
>The thing about drywall mud is that it shrinks while drying and cracks easily if applied to thick. Analyze the cracks and determine if they are mud cracks or settling cracks. Do they look like dried yard mud in August after a rain where the field is relatively flat with cracks running through it or is the field heaved and shifted on either side of the crack. Probably the former so just sand and keep applying thin coats until level. Just be careful about sanding into the tape or paper.
Ray
