Hey Ellis ...... try this again
Joe Burke
>Still curious Ellis .....
You mentioned two things in a past post about libraries that you might clarify for me.
The bit about the face frame overlapping the stile of another cabinet. I might need a visual for that.
I always build with a plinth. Matter of fact, I just finished a room full of book cases done that way. Floor to ceiling over 8' tall. How do you scribe to the ceiling? That's assuming you want the cases to fit tight to the ceiling. I'd need to leave room to be able to lift and position the cases without hitting the ceiling. I've pitched scribing molding after the cases are in. The last job had a ceiling that was awful. I mean AWFUL and it involved crown.
That transition from cabinet to ceiling is the rub for me. Particularly a very out of level ceiling.
Re: Hey Ellis ...... try this again
Relentless :-)
>Hi Joe,
Sorry I got sidetracked the other day. I'm still way behind the eight-ball, but maybe I can try to answer your questions, at least based on my own experience building and installing rooms full of cabinets.
The overlapping face frame concept is pretty simple. You leave one of the vertical face frame members off one cabinet and let the face frame of the next cabinet overlap it. This way you can put a final finish on everything and have it all go together seamlessly on the job.
Regarding scribing to the ceiling, there are a lot of ways to skin that cat, but a lot depends on what the crown molding situation is supposed to be, and some options are dependent on the amount the ceiling is out of whack. If you have any crown molding or other molding at the ceiling, you have that much room to play with, so scribing is unnecessary.
If you want the face of the cabinet to go tight to the ceiling, you need to scribe it somehow. The problem is that, with the plinth in place, you can't put the cabinet directly under the path on the ceiling where the face frame or scribe strip will fall. One way to handle it is to leave the top face frame member off the cabinet, then set the cabinet on the plinth and just scribe the top face frame member to the ceiling.
You never did mention how far out that ceiling is. If it is several inches, it's going to be noticeable no matter how you scribe or mold over it. AT that point, you can decide to lower the ceiling by building a flat soffit, the way a lot of kitchen cabinet jobs are done. The final decision is largely an aesthetic one between you and the client or architect.
Hope this helps.
