Re: worksharp ws3000
Carol from AZ
>Hi John,
The plates are horizontal. The shaft is vertical, driven by a short belt to gear down the RPM, which I don't remember. But as I recall I wanted something in the range of 200 linear feet per minute. So some calculation with the circumference of the plate to get the idea RPM and then some driven/driver pulley calculations given the RPM of the motor.
The plates rest in a shallow dish made of HDPE, because I had it. I routed it out because I did not have a lathe. The Acrylic is 3/8" thick, so the dish is 1/4" deep.
No toolrest. I have been able to freehand chisels and plane irons. Don't know what I will do about turning tools yet.
And sorry, no pictures. It was built as a prototype to see what other features I might like. One I decided on was a reversible variable speed motor, which I acquired but haven't made the conversion yet. Maybe next year when I am out of school for a year on internship and with, hopefully, some free time. I miss the sanctuary of my shop.
A side story, if you want to read further. When I got it done, a friend was skeptical that I could take a store bought 1/2" chisel and put a mirror finish back on it and razor sharpen it in ten minutes or less.
He brought the chisel. I commenced to sharpen. Right at ten minutes, and that would be the worst case scenario. Once that back sports a mirror finish, its a snap to sharpen, even if it has been used as a paint can opener. That said, it does not nor was it intended to replace my bench grinder. :) In an hour of BS'ing, I sharpened everything in my shop.
Hope that helps.
