Jet 14" BS... table fence hole location?
Dave Morris
>Short Version--
Jet BS owners, on "your" saw, how far from the bandsaw table's surface are the holes used to mount a fence? By that, I mean the distance of the hole measured from the top of the table.
Long Version---
Uh-oh... seems I have ANOTHER complication with this old saw. When I bought all the new parts I'd need for restoration, one of the upgrades planned was a Kreg fence. It's been sitting all alone awaiting use while the restoration has crawled along. Finally get to install it today, and lo and behold, I notice the holes in the table for mounting a fence are centered 3/8" below the table's surface--- that's right, the same depth as the miter slot.
The Kreg website, the Kreg manual for the fence, and even the guy at Woodcraft (where I bought the fence) said it mates right up to all Jet 14" bandsaws, so I hadn't looked at the fence mounting rail until today. In fact, the Kreg manual has a highlighted "tip" section pointing out the use of a combination square to make sure the fence rail is set *below* the miter slot. I start to install it on the saw, and see the fence rail extends up past the bottom of the miter slot by a good 1/8", even when dropped to it's lowest mounting position, effectively blocking the use of a miter gauge. Yeah, the vertical mounting slots in the Kreg rail line up with the holes in the Jet BS table like Kreg said it would, but I guess with this older Jet BS, the holes are much closer to the table's surface. Grrr...
Well, rats! I'd really looked forward to using this saw with it's new fence this weekend. :-(
So, options... Install the fence and forget about using the miter slot? Return the fence and buy another brand? Take the fence off each time I need to use the miter slot? (major PITA factor) Grind the offending portion of the fence rail away so I can leave it in place and still use the miter slot? (worried about rail integrity on that one)
Or just build my own BS fence?
Dave--- who's gunna contact Kreg this week and tell them to upgrade their "Fence Compatibility Chart" on their website, cuz their fence does *NOT* fit all Jet bandsaws
