Festool Question?
Festool Question?
Festool Question?
>It has slowly dawned on me that many of my tools are getting a little long in the tooth. My skilsaw is a B & D Sawcat that must be thirty years old. The other day the knob broke and I repaired it because I did not have time to even shop for a replacement. I'm thinking replacements are inevitable.
I know a lot of you really like your Festool products. Do you think they will last thirty years? Are they well made and durable? Or are they destined to sort of come unglued with age. If I have to buy some new tools, I want REAL ones that will serve me well for the rest of my life, not cute, the real deal.
Re: Festool Question?
David Yoho
>Barry, Festool tools seem to be built for the professionals that will use the on a full time basis. My Rotex sander even came with some spare parts that are probably those that will need replacing sooner than the tool itself will wear out.
I was just talking to Ray at Woodcraft yesterday about this topic. We both agreed that it's hard to convey to someone that's never experienced using a Festool tool why the cost is worth it until they get one for themselves and use it. Yeah, they're expensive up front but worth every penny once you've used them.
My 2 cents,
David
Tom Stockton
>I think they will hold up just fine. That said they are fairly high quality precision tools so they won't take being thrown around and still perform at a high level but they aren't like a ferrari and need to be babied.
I think you need to look at what you use your tools for and go from there. If you use your skill saw for mostly construction stuff a festool would not be my first choice, if you needed it to cut up panels and more in shop uses it is a great tool for this.
I have a 150/3 sander and like it a lot and the only problem I had was the cord went bad which is a $42 bummer including shipping.
Tom
Jesse in New Mexico
>Well Barry, I've given up trying to predict the future, especially 30 years out, but I'll get up on the soap box anyhow. The previous advice was good, if you want a tool for rough work, the precision tools probably aren't the best choice. The sanders will probably keep going for a long time. I'm thinking that when I ding my guide rail, it will need replacing. There are some "consumable" plastic parts in the Festools (e.g. plunge saw splinter guide) that I will probably replace. Having said that, my tools take a lot of abuse. They have all been dropped on the concrete floor multiple times (my bad ....), and they have not suffered a bit. But if you are buying for precision, expect more maintenance than buying something to hog wood.
Festool does have a 3 year guarantee, for what its worth.
If you are looking not to buy more tools, forget Festool. After the first one you will be hooked, and saving your lunch money to buy the next one. :^)
John Stegall
>My first Festool was the circ. saw (before the current model came out) and I bought it for a jobsite saw. Why? Because I often needed to make precision cuts, especially in sheetgoods on the site. When I had a problem (or rather needed to know if it would do such and such) I posted over on August Home's site (before moving here). Bob Marino posted back and offered to help. When I finally realized what I needed to do was very possible (reading the manual would have told me what to do) and I was so impressed with Bob's service, I bought a second, then a third, and just recently a fourth Festool.
I owned a Milwaukee circ saw that was great for rough work, but the festool has proven excellent and the Milwaukee has a permanent diamond blade in it for masonary work.
You've seen others post about how much sawdust it (Festool Vacs) sucks up...it is true.
Re: Festool Question? *LINK*
Brian in Sandusky, OH
>Well, I own the TS55 circ saw, router, rotex, domino, dust collector, and I built my own huge MFT, which you see at the link below.
If I were doing it all over and reinvesting money in woodworking tools from scratch, I'd buy a big Felder combination machine, a big bandsaw (laguna or minimax) and everything else would be Festool.
If you are serious about woodworking, my opinion is that there is no comparison. Everything that they make is the best in its class.
If you need a tool for rough work, or you won't use it very often, then buy probably buy something else.
Jumbo MFT
Lasting power tools...
HC Sakman
>In my opinion, power tools are disposable, but don't get me wrong, I don't mean "single use". What I mean is, a power tool works efficently for minimum of 4-to-5 year under frequent, if not heavy use, it pays for itself couple times over during that period. Now, if you're a hobbiest, it may be a different story.
I think what you do with a tool is the main criteria, not how long they last. For example, using Festo circular saw for chopping 2x4's is a waste of money and torture to that precision tool. $75 ~ $150 Dewalt or Milwaukee will do a very fine job, but for occasional use for rough jobs, $50 Skilsaw would suffice.
Just my 2 cents.
Chico...
Marym
>My guess is that the tools will probably last that long, and so will some other brands. I have a couple of Porter Cable routers and circular saws that are over twenty years old as well as a PC belt sander from the same age, and I expect these will last 30 years easily.
The Festool stuff is very good, some products better than others. I have the Rotex sander which I love, but I have used a Bosch which is probably just about as good. I also have the Festool barrel grip jig saw, which I do like, but I dont think it was worth twice the price of a Bosch or other some of the other brands out there.
I would guess the circular saws are worth the money, especially since you are buying a system, with an integrated guide.
You would have try these tools out for yourself to see if they are worth it to you. For me they are worth it, except for maybe the jigsaw.
Good luck
JackLane
>Barry
I have mixed feelings about Festool products. Generally speaking I think MOST are great products but a little over priced. I own a cabinet shop and invested heavily in Festool products a couple of months back because my guys were wearing everything else out too fast, particularly sanders.
The circular saw is probably the finest hand power tool I've ever used. I find new uses for it every day. On the other side of the equation, I bought the RO-125 sander to sand face frames. Nobody in the shop could make that thing sand right. We changed pads, changed paper, adjusted the vacuum settings, even traded the sander thinking that particular unit was a lemon. The problems got worse. BTW, it buffeted and was just generally impossible to control. It also left terrible swirl marks. A $90 PC R/O does a much better job. I called Festool and they admitted they were having a lot of complaints with that particular sander. I surrendered on Saturday and moved up to the 6" Rotex sander. The jury is still out on that one. If it doesn't work, I'm taking it back to Woodcraft and getting 2 Bosch 6" sanders.
I also bought one of the MFT tables..the larger one. My wife made me :-). I thought it was going to be a waste of money, but boy has that thing come in handy on job sites. My guys have also stopped using the sanding table and are using this one. They like the height and the little clamps.
Good luck
Jack
