>We moved some furniture around in my son's room recently, and now the area that the bed used to be over is open floor. There's about a 6' area near the wall that squeaks when you walk over it.
Floor is carpeted, so I can't get at it from his room, but it's over my shop, and the joists are exposed below - I can mostly get at the underlayment from below (except for some pipes and heating ducts), and I don't see anything unusual from the underside.
Is there an easy fix to stopping th squeak from below, or do I have to live with it?
>At the link you'll also find a application for hardwood floors plus other fixes [under "Specialty Fasteners"] which can be applied from underneath (in your shop?)
>You may get some excellent ideas here, but if not you can post over on Taunton's FineHomebuilding website. It is a pro's hangout but they give great advice and if you identify yourself as a HO (home owner) they usually will even include links to posts with photos.
BTW, they also like it if you can post a photo showing what you have to work around, and the part of the site you want to post in is called Breaktime under General Discussion. You'll have to register first but it is free.
>As a former builder and current Home Inspector, I've seen a few squeaky floors.
One thought is leave it alone. It will let you know when your son is slipping out of bed going to the bath room or to get a beer.
Another thought is: Its cultural. In Japan they have floors they design to squeak on purpose. They are called Nightingale floors and serve to let you know when the Ninja's are sneaking into your house or your daughter is trying to elope. (Bear in mind, elopement is a lot cheaper than a big wedding.)
A third and more practical response, something is moving. Either the subfloor or underlayment is moving and the edges are rubbing together or the material is rubbing on the nails. The squeaking or chirping is like a musical instrument in the sense that movement is required to make noise. You say the underside of the floor is open for inspection. Have someone make the floor squeak while you watch closely from below. If you can see the subfloor moving, you may be able to glue it with something like Liquid Nails, used like caulking on both sides of the joist. Also, from above, you can pull out he carpet and screw the floor tightly to the joists. If you do not wish to pull out the carpet and reinstall it, you can nails right through it. I always liked spiral shank siding nails. They are 8 penny and long enough to do a good job. The head is small enough that you can drive the nail down close to the carpet and use a razor knife to cut on strand of the backing. Then you pull the carpet up over the nail and use a nail set to drive it the rest of the way. A few well placed nails into the joists should do the trick. You can use trim (very small heads) screws through the carpet also, but a friend tried it and managed to unravel a thread out of the carpet. Some people just drive finish nails straight through without bothering with the cutting of the backing, but my experience was that they did not hold as well.
PS, When I was building and I had a squeak, I would pay the carpet guys to go back and pull up the carpet and fix the floor and reinstall the carpet. One day I caught them nailing right through the carpet. I said to myself, I can do THAT, and never paid them again.
>When we replace our carpet, I drove 15# of drywall screws into the joists! Sucker stopped squeaking!
Where we were not ready to replace the carpet, I located the joists from the basement side by driving two nails up through the floor, strung a line between them, then carefully cut a 1/4" slit in the carpet backing (pulled the fibers apart to get to the backing). I used 2" drywall screws and screwed through the slit into the floor and joists about every 2' or so apart. No squeaks, no pulled carpet fibers. That was 4-5 years ago and the floor is still quiet.
I'll drift on over to the forum you mentioned - I'm sure I'll get lots of great ideas there. Good to know another source of knowledge (though WoodCentral is still my primary source...).\
>Some great information here - I think I'll try the spiral shank nails and nail set from above.
I'm not too worried about my 4-year-old son getting up to steal my beer (He's already learned not to EVER touch daddy's beer!)
On the other hand, if anyone has some ideas on how to MAKE the floor squeak in my DAUGHTER's room, I'd like to hear it. I can handle my son sneaking off for a beer, but not my daughter sneaking off for Lord knows what. Thankfully, she's only 7, so there's a few years yet before I have to figure out how to booby trap the house...
>You can drill pocket holes in the floor joists and screw into the floor from below. Just ensure that the screw is the right length and does not come up through the top surface. Kreg or any other pocket hole jig will work.
>If you are forced to work from the bottom, the best trick for me turned out to be bottom bracing. I cut 2x2 strips, applied gorilla glue on the edge next to the joist and the top side against the subfloor, placed them next to the joist against the subflooring, jacked them up tight against the subfloor and screwed the 2x2 into the joist. I have used the drywall screws from the top side with good results but this has been the best fix from the bottom for me. Good luck and quite floors!
>I have seen quit a few tries at fixing squeaky floors the only one that always works is using sub floor adhesive, you can get it at any hardware store. It is always used on new homes when the floor is laid on the joists. Just apply it to the floor were it meets the joist.
