Re: OK Mark, David and all...
Bob Dodge
>Joe,
Get yourself a decent acoustic guitar. The two elements that are of prime importance if you want a positive experience, are "playability", and "tone/intonation".
Playability has mostly to do with neck set-up. You want a guitar that has a nice easy "touch". Nothing will frustrate you as quickly as a guitar with a poorly set-up neck. You want the strings fairly close to the fret-board to allow easy fingering, but not so low as to cause "buzzing". Look for adjustability.
A guitar with poor intonation, is to be avoided at all costs. No matter how well you tune your guitar, as soon as you switch chords, it'll sound "out of tune". You don't have to break the bank to get a guitar with decent intonation.
Tone, is something you'll get with proper construction, and quality components. Look for a "solid-top" guitar, not "laminate". Generally, solid spruce is the material of choice. Finger-pickers/ soloists, may lean more to a warmer sound, such as that produced by a cedar top.
Inexpensive guitars often use laminated woods. The priority for you is to find a guitar with at least a solid top, followed by a solid back, then the sides.
You'll find different guitars have different "voicings". That has a lot to do with the size and shape of the guitar, as well as the bracing used inside the body. Some guitars are designed for aggressive strumming, others, a more delicate touch. A "jumbo" or "dreadnought", will usually have deeper bass and volume than a smaller-bodied guitar, but, don't get the impression that a smaller-bodied guitar is lacking, especially in finger-style.
Tone-woods also affect the cost of the guitar, as well as the tone. Generally, the less-expensive guitars will use sapele for the body and sides, followed by mahogany, maple, then the rosewoods. Each have their own particular sound. Depending on the manufacturer, you'll even find exotics such as koa, or cocobolo.
In my opinion, there's nothing worse than buying a "cheap guitar" to learn on. Inexpensive doesn't have to mean "cheap", and it's a relative thing.
Buying "used" can be a great way to get started. Be careful however. Know the instrument well before taking the leap. DO NOT buy "on-line", or, "sight-unseen". Try it first.
If you want a good guitar, go to a well-stocked music store, and look for a Taylor guitar. The playability, intonation, and tone, are superb, and they have a huge price-range. Even if you don't buy one, it'll give you a good idea of what a nicely set-up and constructed guitar can do for you insofar as playing enjoyment is concerned. Also, you won't lose your shirt if you decide to sell the instrument.
Try to not be influenced by "looks" alone. There are many great-looking cheap guitars out there, and many are nothing but junk. Playability, Intonation, and Tone should be your guidelines.
Good luck,
Bob
