Zeroing in on 14" JET bandsaw
Pete LaBelle
>Guys -
Have my sights set on a JWBS-14CS closed stand 1hp bandsaw. Any reasons why not this model?
Any great deals out there ?
Thanx....
Pete
Pete LaBelle
>Guys -
Thanx....
Pete
Re: Zeroing in on 14" JET bandsaw *LINK*
Mark Kauder, Phenix City, AL
>Take a look at the Rikon 14" ultimate bandsaw. Same price range, more good stuff.
http://www.rikontools.com
>Sorry, my bias showing through. Deluxe bandsaw.
Mark
Rob Stokes in North Vancouver
>Got one, plan on keeping it. I've got a 6" riser and I'd recommend one. I resawed some 10" maple the other day and it was slow, but the cut was fantastic - all 6' of it. Dust collection is virtually non-existent in it's stock form, but let me know if you get it and I'll post a pic of a PVC "thingy" I made for mine - cheap and works great. I also added cool blocks - for me they're cheap insurance.
Not sure what you're paying, but I got mine used for $450CDN (about $275 US at the time) and it had been used less than 1/2 dozen times. I'd not buy new, but then again I'm like that :)
Rob
>Good Afternoon Pete,
I've had mine for almost 10 years. It receives moderate use every day, including resaw work. I have never installed a riser block. I've never had a problem with it, except the dust collection. I solved that by installing a 4" black plastic DC port in the lower door and that mod has been wonderfully effective. The saw is always easy and quick to tune. I've added an aftermarket fence. No "cool blocks", I use white oak blocks instead. A set costs nothing and seems to last forever. I am very satisfied with the overall quality of the tool and wouldn't hesitate to buy it again.
George
David W. Dougherty
>I have the deluxe model with the cast iron wheels. I love this saw. The only upgrades I'm considering are 1) a better spring (specifically the Cobra Coil (TM) spring that LV now sells); and 2) the Spinner 3 tensioning crank that Highland Hardware sells. I don't need the riser block right now (I'm a violin maker and I just don't have to resaw very wide boards), but that might be something for the future. I did start using Cool Blocks (TM) and they are an improvement over the resin blocks supplied by the manufacturer.
I also highly recommend the Highland Wood Slicer blades for resawing; worth every penny IMHO.
Good luck with your purchase!
David
Doug in Denver
>I love mine. I also made a PVC dust collector, but it wraps around the blade below the table so the dust never gets to the lower wheel. Glad to send pics of mine as well.
What am I Missing?
Ric Taylor
>I bought my Jet 14" bandsaw new several years ago, and it works just fine for me. But several posters have commented that they had to install their own dust collection system. Mine came equipped with a 4" dust collection port, on the back side next to the lower wheel. My dust collector sucks up the dust just fine through that port. Only a little bit is left on top of the table.
Perhaps it would be a good idea to check the one you intend to purchase, and make sure you get one with the port built in.
Ric
Thanks for your 2 cents worth !
Pete LaBelle
Agree With Rick,
>Good Morning Pete,
My retrofit DC port took only an hour or so to install. The lack of a factory installed port wouldn't turn me off or nix the deal. It is a "must have".
George
CARL BARTON
>Rob,
I bought the 14 in Jet a few months ago and I have been trying to figure out how to set up a dust collection system. I would love to see what you have set up.
Carl
>Carl - here's a lousy picture, but it'll give you the basic idea. I'll take more as soon as I can.
Basically it's a piece of 4" PVC with a 45 at the top and another piece of 4" PVC out of that. The whole top section (including the 45) was then trimmed to allow the thing to snuggle up as tight as possible to the underside of the table and to wrap around the lower guide blocks etc. It took a few test fits, but it's not at all hard to do. the DC blast gate is actually glued to the bottom of the PVC pipe and I cut the "hose taper" (that nested inside the PVC pipe) down as much as I could in order to clean up the air flow (remove restrictions)
The plywood "rings" around the lower PVC section are actually split in half and re-fastened with a couple of screws. The ID of the rings is barely smaller that the OD of the pipe. This allows the rings to be loosened off to adjust their position on the pipe and tightened to stay there. the rings have a flat side where they meet the side of the band saw and on that flat side I installed a couple of #10 wood screws in each ring. These had the heads snipped off so they now act as positioning dowels. Also in each ring I embedded (epoxied) a couple of Lee Valley 3/8" rare earth magnets.
Lastly, where the rings lay flush against the cast housing of the band saw I drilled clear holes in the saw's lower casting to correspond with the locating dowels. These to not affect the structure of the saw in any way.
Once all that is done I slipped the rings into the holes and the magnets held them there. I backed off the split rings and maneuvered the PVC pipe to where I wanted it. If memory serves me correctly I did the final trimming of the PVC pipe at this time too. Once it was all in place I simply snugged the split rings to hold it's position.
This set-up doesn't facilitate the table at 45 deg. If you need to do that, or of you need to pay attention to the lower guide blocks, or if you need to change the blade, you simply remove the apparatus by grabbing it and pulling it off. When you're done, you re-position the alignment dowels and it "snaps" back in place again.
In conjunction with this I also bought a cheap vegetable brush from the grocery store, modified it, built a small bracket and mounted it in the lower section to clean the dust off the lower wheel as it spins. Lastly, the scratch and dent se3ctio of my local hardware store had a goosneck light for a Dewalt scroll saw on for $10. It's now mounted to the saw as well to provide task lighting right at the blade.
Hope that helps!
Rob
>Good Evening Rob,
That is an intrigueing solution to the dust problem. Does it interfere with the ability to tilt the table?
George
>Yup, sure does interfere with tilting the table. The table can't be tilted with it on, which is why I made it easy to remove (pull it off and set it aside).
Rob
Re: What am I Missing?
>Rick - My old 12" JET BS had the same thing ('cept it was a 2 1/2" port) cast right into the back of the saw. It worked really well. But for some reason the 14" saws never came with that. Sure wish they did, but they didn't (maybe they do now??). However, a few $$ worth of PVC and a little time and I've got no complaints now.
Rob
CARL BARTON
>Rob,
Thank you very much. :)
Carl
Ric Taylor
>Like I said, my 14" Jet bandsaw came equipped with a 4" dust collection port. I bought it about 3 years ago.
Ric
