Joining MDF panels
Joining MDF panels
Joining MDF panels
woodhack
>I need to join two 3/4" MDF panels on the ends. I've tried pocket screws but haven't been able to get a flush joint. The one panel splits when the screw enters it. I'm using a 1 1/4" course thread screw. Maybe I'm using the wrong screw. Any suggestions?? Would McFeely pocket screws work better? I'm using the Kreg clamp as recommended. Thanks for you assistance!
Re: Joining MDF panels
Tony Sade (Charleston, WV)
>I just end and edge glued some rather large MDF panels for a computer desk using just Titebond II. I can't be sure, because I added some HPL to the top and the whole thing will be banded with maple, but I suspect that the glue alone would be sufficient. Depends on what you're planning to use your assembled piece for, of course.
HTH
Tony
Jim Dillon
>Woodhack,
Normally, as you know, you don't have to predrill into the second piece for Kreg-type screws to work. But MDF might require a bit of a predrill using the Kreg hole as a guide to avoid the blow-out you are seeing. I know for normal edge to face joining of MDF, conformat screws can be used which are not cheap, nor is the special drill bit needed (all available from McFeely). Plus I think those screws are too long for your use. While I use them, I can't imagine that the McFeely Kreg coarse screw would offer that much advantage. Then again, upon reflection, I think the McFeelys have an auger tip on them which might penetrate more cleanly; might be worth a try. I would for sure use glue on that edge to edge joint as I can't imagine it being very strong with just screws.
Jim
Re: Draw bolts. No, not "drawer."
Al Stokka - Cambridge, Iowa
Another thought...
Jim Dillon
>... I had this morning was to use biscuits with epoxy to align and provide strength. Using water based glues (like Titebond) might swell the MDF and you would end up with what you have now. Then again, maybe just a little glue would do the job.
Jim
Dave in Haverford PA
>Biscuits (without glue) are a good idea to keep the boards in line. Use fine thread pocket screws available from McFeeley, Set stepped drill bit to include a short pilot in the second board. I would not use yellow glue as it may cause swelling. Don't know, but perhaps epoxy would be OK. Good luck!
woodhack
>Many thanks for those responding to my problem... good suggestions. It seems MDF is a bit more fragile than wood or plywood. As I work with it, I find I don't care for it too much. It's nice to work with as far as stability and no grain issues, but it has it's faults too.
Thanks again to all.
