By Derek Cohen
I have concluded that an elliptical or oval leg profile (see earlier thread) is not practical. This is a shape would be constructed with CNC machinery in the absence of special shaper/router bits. The shape was my wife’s choice, not mine – I prefer rounded, tapered legs, ala the Wegner The Chair style. So back to the drawing board.
For interest, I had drawn up and mocked out the chair. I still like the overall design, but the top section needs some more tweeking. It is too high to rest arms on and fit under the table top …
The design of the chair needs to compliment the bentwood chairs here, which are original early 1900s. The table is to be replaced with a longer, wider one.
This table is over 200 years old, and has great sentimental value. It is built of Yellow Wood (top) and Stinkwood (legs). We bought this after getting married. Now, 42 years later, Lynndy wants a larger table. The plan is a top in Rock Maple and round, parallel legs in Jarrah. Mid Century modern, and the aim is to blend two modern Mid Century carvers with the bentwood chairs. Consequently, a lighter look for the carvers is needed.
Here is the re-design.
The legs have been made thinner, with 25mm top and bottom, and 32mm around the seat area. The 35mm thick seat will be attached with mortice-and-tenons (not sure yet whether integral or loose tenons). These will be 25x10mm.
The curve has been retained in the legs … since this is a desired feature to soften the look and also link with the bentwood chairs. The legs will now be round and not oval. The complication, in shaping, is that there is a taper and a curve.
The height of the top section has been reduced significantly. It is possible to see the original design below the new design …
All-in-all much slimmed down.
Then there are finer details being worked out, such as the curve at the rear of the backrest and seat to link with the roundness of the bentwood chairs. The transition from the legs to the arm rest is borrowed from Hans Wegner …
- Shaping elliptical, curved chair legs
- Designing a dining carver chair
- Dining room carver chairs – Take 2
- DC 09 Chairs – completion
