Some Rules For Good Design?
The question, "What is a good design?" is all too often answered with, "There are no rules", "You just know it when you see it.", or "You either have it, or you don't."
I have heard these answers from the "experts" at AAW Chapter meetings, from demonstrators in various venues, and from informal discussions among woodturners. Many articles in "American Woodturner" have made the implication that there is an "insight" that is known only to a very few among us. It would appear that there is no hope for those of us who are not gifted with a natural ability to discern pleasing shapes and proportions.
Nothing is farther from the truth. Pleasing shapes have been found in every civilization throughout history, and they all share the same basic rules of good design that were first taught in ancient Greece. When we deny their existence, we are either admitting that we are artistically illiterate, or that we refuse to believe that the rules, used for 3000 years of pottery and furniture design, could have any application to articles turned from wood.
We can either mathematically calculate pleasing proportions from an ancient formula, or we can use some "Rule-Of-Thumb" formulas.
The "Rule Of The Golden Mean".
The Greeks perfected and used the "Golden Mean," a formula for the ratio between the short side and the long side of a rectangle that will appear balanced to the viewer. I learned to use the "rule" for furniture design back when wood shop (Manual Arts) was still a required subject in high school.
The Rule Of The Golden Mean simply states that: "The smaller is to the larger as the larger is to the whole." Without a lot of discussion, this can be reduced to: "The relationship between the smaller and the larger is the ratio of 1 to 1.618". To complete the "rule" the sum of the length and width is the same as the length multiplied by 1.618.
We can find examples of the rule in the sizes of tables and other furniture. A 72" long dining table is 45" wide. An oval coffee table that is 42" long is 26" wide. The 60" round dining table still has a balanced proportion with a 36" leaf inserted in its center. A bookcase that is 72" tall will be 45" wide. All of these examples fit the "Golden Mean", the larger (length) is the smaller (width) multiplied by 1.618.
Bowl Design
To apply the "Rule" to a bowl design, we divide the diameter by 1.618 to determine its height and divide its height by 1.618 to determine the diameter of its base.
As an example: If we want to turn a 10" diameter bowl, its height will be: 10" ÷ 1.618 = 6.180", or 6Œ" height And the base diameter is: 6Œ" ž 1.618 = 3.72", or 3Ÿ" These dimensions will give us a bowl of pleasing proportions, as taught by the ancient Greeks. What we do with the curves between these dimensions is the topic for another discussion.
Rules-Of-Thirds
There are other rules of proportion that we can use. One of these is the "One Third-Two Thirds" Rule that is easier to use and similar to the "Golden Mean" within the dimensions that we would use for a bowl design.
Rule 1 - "The bottom diameter is 1/3 that of the largest diameter." Using our same 10" bowl as an example, the bottom diameter would be 3 1/3", but 3Œ" can be used for easier measurement.
Rule 2 - "The height is either 2/3 (preferred) or 1/3 (optional) that of the largest diameter." Using the same 10" bowl, its preferred height would be 6Ÿ", or it could be a 3œ" height in its shallower form. Both would appear to be proportional to the viewer.
Rule 3 - (Adapted from vase design) Bowl shapes have a more pleasing appearance when the maximum diameter is not at the top rim, but is located below the rim which is a smaller diameter. How far below the rim can be defined as: "If the height from Rule-2 is divided into 3 equal parts, the largest diameter will be 1/3 down from the top." This rule can also be inverted, locating the major diameter up 1/3 from the bottom. Using our same example from Rule-2, the 10" bowl that is 6Ÿ" in height", will have its maximum diameter located 2Œ" down from the top, or up the same amount from the bottom in its inverted form.
Rule 4 - (Mine) I added this rule as a follow-up to Rule-3 after being asked for some guidance on how much smaller the rim diameter should be. I measured several bowls that looked pretty good to find something that they shared, and came up with the following: "The diameter of the bowl at the rim is smaller than the largest diameter by half the distance that the largest diameter is below the top of the bowl."
In other words, for the same 10" bowl that is 6Ÿ" in height, the largest diameter is located 2Œ" down from the top. With this "rule", its diameter at the rim would be half that amount smaller, or 1 1/8" less than the 10" diameter, making it 8 7/8" at the rim. If this bowl had the alternate shape that placed the largest diameter near the bottom, or 4œ" below the top, the rim would be smaller by half that amount, or 2Œ" smaller that the 10" diameter. And the bowl would be 7Ÿ" diameter at the rim.
Conclusions
Now we know why the bowl we turned from that expensive 10"X 10" X 3" bowl blank "just didn't look right". Using either of the rules, the blank should have been at least 6" thick for the 10" diameter bowl. A better use of the wood may have been cutting it into four pieces and making a set of 5" bowls that had a more pleasing shape.
Vases and Urns
Considering that a vase is an elongated bowl, we can use the same rules, with one exception. The difference is that the relationship between diameter and height is reversed, and Rule-2 is modified to read: "For turning a vase or an urn, the largest diameter will be either ? or ? that of the height." All other rules for the magnitude and location of the various diameters will remain the same.
Russ' Rules
There are several other "rules" that I have learned, either from experience or from other woodturners.
