Basic Sharpening Tutorial
by Bob Smalser
[One of our friends queried:]
Bob, Could you post a tutorial on how you sharpen? I use waterstones but hate the hassle of trying to keep them flat. I have my grandfathers oilstones some maybe 50 or 75 years old (just guessing)...I would love to see your thoughts in pictures.
Glad to help. I dont use waterstones, but I did spend years using composite stones that also hollowed badly. There are a couple basic techniques you can use to minimize the hollowing. The first is to use the entire surface of both sides of the stone wherever you can....not just the center...and the other is to do more on the grinder and less on the stone.
Using the entire stone sometimes means you have to forego some jigs, but its always good to develop your ability to sharpen freehand as I can think of dozens of situations in even hobby woodworking where your bench and jig wont be available. All the grandiose words written in the last couple decades on honing, all the expensive gizmos for sale to help you do it, and all the trouble folks seem to have with it puzzle me some. Grind that blade correctly, and the difference in cutting speeds and technique between oil, water or composite stones is meaningless because there isnt enough honing to be done to measure a difference. Moreover, why would I want to trade my hundred-dollar Taiwanese large pedestal grinder for a much-slower, several-hundred-dollar Tormek?
So Ill go you one better on your question. Ill convert an old abused, 2-dollar half-inch firmer chisel to a small skew for lathe work. Lotsa grinding required here...and on burnable 19th-Century carbon, not burn proof High Speed Steel.
Get good enough freehanding on your stones, and it takes no longer to put your best edge on that carbon skew using stones than it does to put an inferior edge on an HSS skew using a grinder.
I mark the bevel I want on the chisel using a bevel gauge and carbide scriber...
...and grind off the old edge square to the line. Looking at the squared-up flat I made, the chisels old bevel largely remains on the bottom side in the pic, but the flat penetrates to at least the center of the bevel at the point of the skew to leave enough steel there to grind a perfect bevel and edge next. The objective in all sharpening is razor-sharp...but also consuming minimum steel in the process.
Im using the coarsest grinding material I have...both my coarsest grinding stone and 26-grit sanding disks for the roughing work. The coarser the abrasive, the cooler it cuts and the faster you can do the job without stopping to cool the steel with every stroke. Remember that if you turn that steel blue with the 600 degrees it takes to do it, youve ruined its temper and all that blue must be ground off for that steel to hold an edge. Takes two minutes to grind.
Next I grind the 20° bevel on both sides of the skew. I use the tool rest and the side of the coarse wheel in the 8", 1750-rpm buffer-grinder. No jigs, no Tormeks, just that angle gauge sitting handy on the grinder stand to show me what 20° looks like when grinding either side... working all that out with the wheel stopped, of course. Takes five minutes, taking a little bit off at a time then dipping the tool in water and examining the cut for any adjustments in my hold required. The closer I get to forming an edge, the easier it is to burn the edge.
Learn to watch the trail of grinding sparks flying off the steel—their density and quantity tell you precisely how much steel you are taking off and from where—showing you how uniform your resulting bevel will be.
Heres the ground edge.
Now I take the skew to the coarse novaculite stone fresh from the can of kerosene it lives in and measure what 20° looks like for rough honing. Ill not use a secondary bevel on this edge but hone a flat 20° on both sides. That stone was my uncle's, who built boats professionally from 1930 to 1970...no telling how old it is but its just as clean and flat as the day it was ground. It may even have belonged to his father, a carriage maker.
Having taught a number of young people to sharpen over the decades, the single biggest factor in ease of honing is the height of the stone. Do what you have to do to get it secure and to the level of your belt buckle...higher than your kitchen counters, let alone most workbenches. This gets your elbows up and free from your torso to aid you keeping a consistent angle without any rocker or rounding.
I dip the end of the tool in kerosene and make a few strokes on the stone...then I examine it to see what hold adjustments I need to make. See the flat? I need to drop the angle a tad and apply more pressure to the lower edge of the skew to even up that bevel.
Pressure adjustments are made using the fingers of the left hand while I stroke the tool back and forth using my right. Here Ive wrapped my fingers around the lower edge side to apply more pressure to that edge than the upper or tip edge.
Now you can see I have an evenly formed bevel. It's not perfect...but as only a couple thousandths at the edge really matter, it doesnt have to be. Takes only another five minutes, and if this were merely a secondary bevel on an existing chisel, it would have taken one minute or less.
With the bevel honed on both sides, I clean, buff and phosphate blue the skew before final honing. Cold blue or machinists layout blue applied to your tool before honing will teach you gobs about the effects you are having, as the camera picks up the small details shown better than the naked eye. Especially a 50+-year-old naked eye, and especially flattening your chisel backs....do the rough work flattening backs...not on your expensive stones...but on your belt sander using 150 grit...just remove the bag and clean out the sawdust first.
Final honing is done on the fine novaculite stone. I have no earthly idea what grit or microns these or my black novaculite stone are...and dont especially care. I do know the black stone, which I use only on the thinnest edges, will sharpen a straight razor or scalpel as well as anything I have ever seen. I also know you cant judge the coarseness of these stones solely by their color...I have a fine stone darker in color than my coarse stone.
Note the darkened kerosene on the stone...how uniform it is compared to the bevel being honed. Ground steel particles cause the color. Just like watching the spark trail while grinding, watching the fresh lube get dirty tells you how even your bevel is forming and where more or less pressure is needed.
An evenly formed and flat, fully honed bevel ready for stropping. Took twp minutes...about how long it should take you to hone the back and secondary bevel on a bench chisel.
I strop using a stitched muslin wheel loaded with Knifemakers Green Rouge...there are many stropping mediums, and it doesnt matter which one you use. What matters is stropping your bevel at the same angles you used in honing. I also use a hard felt wheel, but it removes more steel and gets very hot very quickly, and I use it primarily to quickly touch up my turning tools without any honing.
If you are stropping at the correct angle yet the tool is duller after you are done, your error is being made at the fine stone, not the strop. When you hone one bevel, you create a wire edge that is honed off when you switch to hone the other side of the chisel. If your hold and angles are inconsistent, that wire edge can be too thick...an edge that should have been removed on the stones rather than the strop, because when the strop removes it, it breaks it off deep enough into the edge to dull the tool.
The secret to long tool life is to take the five minutes it takes to touch them up after each day's use, keeping those honing angles constant and dropping the honing angle occasionally to flatten the main bevel as the secondary bevel wears. If you never round or rocker your edge.... you can go literally decades without grinding it again.
The final result shaves dry hair painlessly...
...and the finished skew. Total time including bluing and turning was less than two hours.
Proper sharpening can be done well in many mediums...my counsel is not to buy anything new but learn to use what you have. But Im not your guy to ask about water stone grits, diamond paste microns, indexing plates or Tormeks...I only lust after the best novaculite stones ever made—see Hall's website.
NB: Manufacturers of common grinding wheels warn against using materials against the wheels sides, and indicate that wheel failure could result with serious consequences. Ed.
