Using used motor oil as a wood preservative
Using used motor oil as a wood preservative, like for decks, has been a DIY practice for decades, often praised for its low cost and reuse of waste. However, the environmental and health implications are complex, and the practice is controversial. Below, I’ll break down the facts, weighing the eco-friendly claims against the hazards, and compare it to conventional wood preservatives like paints, stains, or sealers.
Pros of using used motor oil as a wood preservative
  1. Reuse of waste product:
  • Used motor oil is a byproduct of vehicle maintenance, and repurposing it for wood preservation diverts it from improper disposal (e.g., dumping into soil or water). In the U.S., about 1.3 billion gallons of used oil are generated annually, and only a portion is recycled properly.
  • Applying it to decks theoretically reduces the need to produce new products, avoiding the resource extraction, refining, packaging, and transport of commercial wood preservatives.
  1. Effective preservative:
  • Used motor oil penetrates wood, providing water-repellency and some protection against fungal decay and insects, extending the life of outdoor structures. Anecdotal evidence from farmers and rural users suggests it can preserve wood for years.
  1. Low energy input for application:
  • Unlike paints or sealers, which may require primers, solvents, used motor oil can be applied with minimal preparation, brushes or rags, reducing energy use during application.
Cons of using used motor oil
  1. Environmental hazards:
  • Toxicity: Used motor oil contains contaminants like heavy metals (e.g., lead, cadmium, chromium), polycyclic aromatic hydrocarbons (PAHs), and other carcinogenic compounds formed during engine use. These can leach into soil and groundwater, especially under rain or wear, polluting ecosystems.
  • Bioaccumulation: PAHs and heavy metals can accumulate in plants, animals, entering the food chains and food chain, posing risks to wildlife and humans.
  • Soil and water contamination: A single gallon of used oil can contaminate 1 million gallons of water, according to the EPA. Even small amounts leaching from treated wood can harm local environments, especially near gardens or water sources.
  1. Health risks:
  • Exposure: Handling used motor oil during application exposes users to toxic chemicals via skin contact or inhalation. Long-term exposure to PAHs is linked to cancer, respiratory issues, and skin irritation.
  • Off-gassing: Treated wood may release volatile organic compounds (VOCs) or fumes, especially in hot weather, posing risks to nearby residents or animals.
  1. Regulatory restrictions:
  • In many regions (e.g., U.S., Canada, EU), using used motor oil as a wood preservative is illegal or heavily discouraged due to environmental concerns. The EPA classifies used oil as a hazardous waste if not properly managed, and improper disposal or use can lead to fines.
  • Some states explicitly ban its use on structures like decks or fences due to leaching risks.
  1. Fire hazard:
  • Used motor oil-soaked wood is more flammable than wood treated with modern sealers or stains, increasing fire risks, especially in dry climates.
  1. Aesthetic and practical downsides:
  • Used oil often leaves wood dark, greasy, and odorous, which may not be desirable for decks. It can also attract dirt and remain tacky, making surfaces slippery or unpleasant.
  • It provides less UV protection than commercial stains, leading to faster wood degradation from sunlight.
Comparison to conventional paints, stains, and sealers
  1. Environmental impact of commercial products:
  • Resource use: Paints, stains, and sealers require raw materials like petroleum-based resins, pigments, solvents, and biocides. Extraction and refining consume energy and emit CO2. For example, producing 1 gallon of oil-based paint generates about 20-30 kg of CO2 equivalent.
  • Packaging and transport: These products are packaged in metal or plastic cans and shipped globally, adding to their carbon footprint.
  • VOCs and toxins: Many traditional paints and stains release VOCs during application and drying, contributing to air pollution and health risks. Water-based or low-VOC options reduce this impact but still require resource-intensive production.
  • Disposal: Unused paint or stain is often classified as hazardous waste, requiring special disposal, similar to used oil.
  1. Eco-friendly alternatives:
  • Modern eco-friendly stains and sealers (e.g., linseed oil-based or water-based products) use renewable or less toxic ingredients, reducing environmental harm compared to both used motor oil and traditional oil-based paints.
  • Some products incorporate recycled materials or biodegradable components, lowering their lifecycle impact.
  • Proper application of commercial products minimizes leaching compared to used oil, as they’re formulated to bind to wood and resist weathering.
  1. Lifecycle analysis:
  • While used motor oil avoids the production phase of new preservatives, its long-term environmental cost (leaching, contamination) often outweighs the upfront savings. Commercial products, especially eco-friendly ones, are engineered to minimize leaching and maximize durability, reducing the need for frequent reapplication.
  • Recycling used motor oil into re-refined oil (for lubricants or fuel) is a more environmentally sound reuse than applying it to wood. About 80% of used oil in the U.S. is recyclable, and re-refining uses less energy than producing virgin oil.
Data points and studies
  • EPA guidelines: The EPA emphasizes that used motor oil should be recycled at certified facilities. Spreading it on wood is considered a form of improper disposal, as it leads to uncontrolled release into the environment.
  • Leaching studies: Research on oil-treated wood (e.g., utility poles treated with similar substances) shows significant PAH and heavy metal leaching over time, especially in wet conditions. A 2008 study in Environmental Science & Technology found PAH concentrations in soil near treated wood exceeded safe levels within 1-2 years.
  • Recycling efficiency: Re-refining used oil produces 1 gallon of base oil from 2 gallons of used oil, with 50-85% less energy than refining crude oil, per the American Petroleum Institute.
  • Commercial product impact: A 2019 lifecycle assessment of wood coatings found that water-based acrylic stains had a 30-50% lower environmental impact than oil-based alternatives, primarily due to reduced VOC emissions and toxicity.
Conclusion
Using used motor oil as a deck preservative has some eco-friendly appeal by reusing waste and avoiding new product production. However, its significant downsides—environmental contamination, health risks, and regulatory issues—make it a poor choice compared to modern alternatives. While conventional paints and stains have their own eco concerns (resource use, VOCs, disposal), eco-friendly options like water-based or natural oil-based sealers offer better performance, lower toxicity, and reduced long-term harm. Recycling used motor oil through certified programs is a far more sustainable way to manage this waste.
If you prioritize eco-friendliness, consider:
  1. Using low-VOC, water-based, or plant-based sealers (e.g., linseed or tung oil).
  2. Recycling used motor oil at local facilities (check with auto shops or municipal programs).
  3. Exploring DIY preservatives like beeswax or soy-based mixtures, though these require research for efficacy.
Photo credit
Title: Using used motor oil as a wood preservative
Author: Peter Martin
Original URL: https://www.woodcentral.com/-/using-used-motor-oil-as-a-wood-preservative/
