Turning
Re: Harbor Freight Hydraulic Presses
Mequipment
Most of the harbor freight presses require extra bracing if your application requires precise alignments when using the press. This usually requires a cross brace to be installed or I have also seen people square the press and weld the corner joints to stiffen the press. When you put a HF press together and tighten all of the bolts you can grab the press and move it side to side an inch or so. Not a big deal for most applications but can be an issue on vertical alignment applications.
