Messages
Re: Arcane question
Arcane question ()
TomD
Whatever you do, do a trial run with identical paper and wood.
I would get a piece of 1/8"plexiglass and put a few small screws, to hold it to the bottom of the drawer, the way they mount stuff in museums. I assume the drawer bottom has a 1/4"ish clearance to the bottom of the drawer, and if you, you would have space for the plexi and hardware.
Presumably you would counter sink the screw heads, in which case be very careful not to overdrive the screws, as they will split the plexi rather easily.
You might consider signing off the plans, as the builder.
