Messages
Re: Super Dust Deputy problem - fittings don't fit
You can crimp the ends of the pipe with a pair of needle nose pliers. Just stick them on the end of the pipe as far as they will go and twist. Over and over until you take a lap. start with a small twist and check the fit. Go over it again until you get what you need.
You can expand the pipe by cutting fingers on the end of the pipe. Cut in about 1 1/2" or 2" and make the fingers 1/2" or an 1" wide. Force them over the outside, tape them and use a hose clamp.
I cobbled my system together years ago and spent a LOT of time making things work together. Calling the maker of the SDD seems like a good Idea.
