Hand Tools
Sorta yes....
metal vs wood threads ()
John in NM
But not when assuming equal torque applied. Equal torque is generally going to mean equal force.
With metal threads you can apply a lot more torque before the threads fail or wear excessively (leading to failure in a shortish time frame). You'd never lift a car with a wooden scissor jack with a the tiny lead screw that most of those jack's have, if that screw were wood. The threads would probably shear off.
I would expect a wooden thread to shear off along the grain at the base of the threads long before you even approach the torque you could apply to a similarly sized steel thread (speaking generally of course, there could well be exceptions).
I think the more appropriate question is just how much torque (and resulting clamping force) do you really need?
