Hand Tools
and the ward *PIC*
David Weaver
sharpened off of the washita - there's a little bit of chromium in it or something. It's not harder than the 26c3 chisel, but it's a little bit more slick on a washita.
The damage was shallower on the ward, the feel similar. It's just a slightly better chisel than I can make yet when the malleting gets a bit more brisk than it should be. (again, typical damage and then a clearer section)
Strangely, this chisel has a soft corner. I have no idea why. I've used these chisels a little bit on the past, but not heavily. I used them enough to realize that they'd be sold way later than most anything else I have on hand.
Here's what happens to the soft corner (eek). You could feel the burr where this rolled over almost immediately, but I didn't spare the rod. It's only about 1.5mm of the 1/2 inch chisel and I just worked the maple with this bit hanging on the waste side so that it didn't have to do as much work.
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
Deflecting vs. letting go
I think that's pretty much it...
Re: Deflecting vs. letting go
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
short follow up thought....
Re: short follow up thought....
Re: Sure...
