Hand Tools
not that much later...the 26c3 *PIC*
David Weaver
as mentioned, 7 cubic inches of maple malleted off directly cross grain. This is a lot of wood to mallet off at once.
26c3 sharpened on a washita, unicorn on the bevel side (opposite side of the picture)
damage started about halfway through, but I made a mark to mallet to and decided to continue and see how bad it would get.
This is typical (there are areas slightly worse and then some areas clear - but strangely, entering into the cut no problem and no bounce like with a rolled edge). for scale, the depth of these nicks is about 2 thousandths.
Another length shown where there's little damage.
I did what I'd call a double length honing after this, it was about double as long as I'd go between sharpenings. fine india (no coarse grinding needed) and then re-do of the uni and all damage as gone.
The deepest notching was maybe twice as deep as the above picture, but taking a picture of the worst gives a false sense - above is more typical. These shallower nicks are still enough to leave a line on the work that you can see. The smaller nicks do not.
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
Deflecting vs. letting go
I think that's pretty much it...
Re: Deflecting vs. letting go
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
short follow up thought....
Re: short follow up thought....
Re: Sure...
