Hand Tools
I didn't check with a metallurgist..
David Weaver
..but I believe manganese isn't added for toughness, just for hardenability because none of the manganese only steels (like 1095 and white 1) have any decent toughness in notch tests, but 52100, which is similar but with the chromium addition is monstrously tough.
I think a google search would find that to be the case, otherwise what I'm seeing is unexplainable. 52100 has drastic toughness compared to the other plain steels I've forged, almost circus-like. When planing, I noticed none of this, because the edge was never challenged. It makes a beautiful planing iron, just like ideally hardened O1 does. It doesn't wear like XHP, but it does wear about like O1.
In doing these bits of testing, though, it's the relative comparison of tools one after another that's valuable - if you use them in isolation, you can't see how stark the contrast is and if you're making them (like I am), then it's really worth chasing to get something that "just cuts and cuts and then refreshes easily.
I'll clean up the 26c3 edge and compare it to the ward. I'm hopeful that it can come close to matching the latter (which is as good as any chisel I've ever used, even though mine's a little later and not as neatly made). 52100 isn't going to have a chance in feel and effort without leaving it much harder. really ideal O1 might.
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
Deflecting vs. letting go
I think that's pretty much it...
Re: Deflecting vs. letting go
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
short follow up thought....
Re: short follow up thought....
Re: Sure...
