Hand Tools
Re: Deflecting vs. letting go
Deflecting vs. letting go ()
Manganese is primarily responsible for toughness. I suspect the Cr is there for wear.
That said, if the test is bashing the edge into maple with a mallet the force resisting Penetration is irrelevant. Bash harder. I can understand that someone that carves for hours a day would be interested in force to create a shaving, but not someone chopping dovetail waste. It takes no more than "love taps" to drive a chisel through a poplar drawer side.
If I need a microscope to see damage at the edge this damage, whatever kind it is, will have no effect on my use of the chisel to remove dovetail waste. What is important to me is how long before I need to sharpen, and when I do, how much effort will it take to correct damage.
David is the only person I have encountered that prefers chipping to folding for edge dulling in a dovetail waste removal operation. The reason for preference is that less metal needs to be removed to correct folding than to correct chipping. In fact I often just rub the edge on a hard ARK stone and it restraightens enough to carry on.
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
I think that's pretty much it...
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
short follow up thought....
Re: short follow up thought....
Re: Sure...
