Hand Tools
I think that's pretty much it...
Deflecting vs. letting go ()
David Weaver
I think that pretty much sums it up, but interestingly, the 26c3 gives up no top level hardness to also be agreeable at lower hardness levels. It just seems like it'll have a wide range where it works well.
Testing of the various chisels is same mallet, same stick of wood, same width of chisel (within reason) and same sharpening method.
I guess to the credit of the unicorn method, I thought 52100 was closer to the ward chisel than it was, but using them one next to the other proved me wrong.
Down the road, I can leave a 52100 chisel very very hard and see what happens. at 350F temper, it will still hold on to a developing burr when it's pushed.
When I temper files and O1 at 350F, they are always chippy, but 26c3 worked fine and 52100 didn't show any chippy nature at all - still all deflection.
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
Re: Deflecting vs. letting go
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
short follow up thought....
Re: short follow up thought....
Re: Sure...
