Hand Tools
It'll look the same...
David Weaver
..it was very hard, but held up fine. It may lose corners easily in heavy work. Chopping maple is resistant compared to most of what we work, but all of the strikes are straight in without much wobble. Where I get in trouble with nice japanese chisels is slipping them in a plane mortise or something like that where they're being worked and turned at the same time out of laziness. Whatever a japanese chisel will do, at 325-350F, these chisels will also do.
AKS (the vendor) provides a curve with parks (which is what I use) and of all of the steels where you can hit the targets in a garage, a steel like this is one (no real need for normalizing, very simple, and gains full hardness right past loss of magnetism, so no guessing like with some other steels that like to be quenched a top hardness another 150-200F plast magnetic (I overshoot on those on purpose as it's better than undershooting).
At 350F, these should be 63/64 (at 380F where they are now, I would guess 62, but the lack of anything other than a tiny amount of chromium makes them feel like there's absolutely nothing abrasion resistant in them. They're dreamy to grind, very "dry" and at high hardness they drop their burr even on a washita without having to do anything.
As tempered in this picture, they're not quite as brisk on the washita, but one quick stroke back and front and 99% of the burr is gone. The buffer puts the uni stripe on the chisels very quickly, too, since there's nothing wear resistant in them. Thus the comment that they would probably make a wonderful plane iron, but one that wears like old water hardening steel.
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
Re: pics...
Re: pics...
Deflecting vs. letting go
I think that's pretty much it...
Re: Deflecting vs. letting go
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
short follow up thought....
Re: short follow up thought....
Re: Sure...
