Hand Tools
Re: short follow up thought....
the knife is nothing to do with friction against wood. It gets sharp and stays sharp longer the the 2 cherries.
Has anyone else ever claimed or measured a difference of coefficient of friction steel on wood as a function of small alloying components? Trivial to measure given the equipment. When I looked into friction of wood on steel I found the coefficient of friction was dependent on minor constituents in the wood, not the other way around.
Is the composition of the steel in the Ward chisel known, if in fact the composition remained constant during the time of manufacturer. . In past times steel from a particular mine excelled is this application or that. When it became possible to determine the minor constituents in steel, composition-property relationships were discovered that revealed why iron from this mine made good suspension bridge cable and iron from that mine was better for something else.
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
Deflecting vs. letting go
I think that's pretty much it...
Re: Deflecting vs. letting go
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
Re: Sure...
