Hand Tools
short follow up thought....
David's knife ()
David Weaver
you may have been thinking about the knife, but what you mentioned is really the jones I'm looking for in a chisel. With enough unicorn, the softer 52100 chisels work fine. The harder ones a little less (but 52100 with a temper of 350F will still deflect and hold bits of its edge, which is kind of remarkable as far as toughness goes).
But when you use the ward chisel or the file chisels or the 26c3 chisels, they go through the wood more easily, and they keep going through the wood more easily.
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
Deflecting vs. letting go
I think that's pretty much it...
Re: Deflecting vs. letting go
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
Re: short follow up thought....
Re: Sure...
