Hand Tools
Re: 26c3 mule...
Re: 26c3 mule... ()
David Weaver
It feels a lot like files - I just wasted a bunch of maple with it and it leaves tiny little chips at the edge, but that's it. Nothing more than a thousandth or so and one would be begging to sharpen by then.
But that's straight in work, and not in the hands of the general public.
Unless I find something wrong, you'll need a set of these to go with the ones that I sent in 52100, gratis. I didn't figure out the limitation of the 52100 at lower temper until after I sent yours. You can use those for abuse work and the 26c3 for everything else. It's just dandy so far tempered back some (at 380F). It should be low 60s hardness at that and its behavior is consistent with that.
I took pictures of the different edges but won't bore everyone with them.
It's not cheap steel compared to other plain carbon steels, but a look at bar stock for CPM M4 or XHP makes it seem very affordable!
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
Deflecting vs. letting go
I think that's pretty much it...
Re: Deflecting vs. letting go
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
short follow up thought....
Re: short follow up thought....
Re: Sure...
