Hand Tools
now I am confused more
What I'm doing would be easy for someone with a forge and an anvil to duplicate.
There's no commercial value in it as 52100 is a forging steel and not a cut and shape steel.
I'm skeptical either of these statements is true if we add "boutique" before commercial.
From what I have read about this steel, and your reports, you seem to have found a good chisel steel. Exploring how to fabricate it into a chisel I can follow. The results would be judged attractive and desirable by all. Anyone that has used one of your chisels will be smitten by how nice it feels and the hand.
Its the heat treating I don't get. With no stake in the ground to know where you are at, and no details of how you got there, any result on performance as it relates to the steel is hard to interpret. Add the fact that you sharpen with complex bevels known to have an overwhelming affect on folding/ chipping and I have no idea how this chisel steel compares to whatever.
I thought you were filing these shapes and forge welding the bolster? I may not know the details what you are doing that results in an attractive chisel that is sure nice in the hands. For me the details either were not provided or got lost in the description of the journey to get there.
We certainly don't know enough about the critical step of heat treating that someone could duplicate. More important what are you doing as it relates to what must be a wealth of information of how to heat treat this steel to achieve the performance it is capable of delivering? If nothing else determine from data on this steel what heat treat should optimize hardness and toughness, send some chisels out to a reliable heat treater (there must be numerous in a stones throw of where you live in the Steel City) and get a stake in the ground to compare your results to.
Heat treating is not easy to do reproducibly or to reach a target. I watch Forged in Fire occasionally. I am amazed at the steel failures these professionals suffer at the hands of their shade tree heat treating. For a time I did temperature sensitive chemical reaction rates in ovens . Determining what the temperature is and how it varies at any spot in an oven showed me that a heat treat oven that produces reproducible results at a target is a marvel of technology.
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
Deflecting vs. letting go
I think that's pretty much it...
Re: Deflecting vs. letting go
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
short follow up thought....
Re: short follow up thought....
Re: Sure...
