Hand Tools
relying on the charts...
Better than O1 ()
David Weaver
.for toughness. I could only guess why manufacturers chose O1 and would probably guess wrong aside from the fact that 52100 in sheet instead of rod or balls is much less common.
Cost is close enough (bohler 52100 vs. american O1) that it doesn't matter (52100 is a little cheaper, but the seller that I use charges enough more in shipping to make it close).
I don't think we'll challenge the toughness limits of either, but looking at the micrographs of both, they don't look much different and why O1 doesn't do as well in standardized tests (or 1095 for that matter) is just a guessing game (Larrin Thomas uses the term "plate martensite" as a speculation on toughness problems).
Messages In This Thread
52100 experimentation continues *PIC*
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
Deflecting vs. letting go
I think that's pretty much it...
Re: Deflecting vs. letting go
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
short follow up thought....
Re: short follow up thought....
Re: Sure...
